Simple Symetrical Amplifier
Old 2nd March 2012, 09:35 AM   #2031
PauloPT is offline PauloPT  Portugal
Send a message via MSN to PauloPT
What's the optimum bias across drivers and laterals?
Those of you who built it (the lateral fets version) how does it sound?
Kind Regards,
Paulo.
Old 2nd March 2012, 09:53 AM   #2032
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Look a bit back, bias has been discussed. Short answer, 150-200mA. For some comments look early in the thread, Nico was talking a bit 'bout his version you contemplate.
Old 2nd March 2012, 10:07 AM   #2033
I'll do
Thanks!
Kind Regards,
Paulo.
Old 2nd March 2012, 11:02 AM   #2034
Try R6,8,11,12=510 Ohm
Also R13,16,23=375 Ohm for ~3mA bias in the drivers and ~100mA in the Lats.
So for 180mA bias what would be the value of this resistors?
Forgive my poor knowledge of electronics design, I'm reading Sedra & Smith - Microelectronic Circuits - for learning but I'm still very in the begining.
Kind Regards,
Paulo.
Old 2nd March 2012, 11:16 AM   #2035
Salas's Avatar
Run .op and manipulate R23 until you will get what you need through the LATs. In reality R23 better be a trimmer. The simulator won't have exactly the same Vbe for the drivers or Vgs for the LATs as each one ranging practical part. Just make Nico's as given but with trimmer R23, trimmer R6 and see if it will bias up and work stable on you. You gotta get hands on to experience how it moves... In mysterious ways that is.
Old 2nd March 2012, 12:36 PM   #2036
With Nico's values for the resistors distortion is huge. The sugested above values work like a charm! Why did Nico used the values that give worst distortion?
Kind Regards,
Paulo.
Old 2nd March 2012, 02:30 PM   #2037
One more thing: could I use 2SK1530/2SJ201 instead of 2SK1058/2SJ162 ?
They are not lateral but close.
Kind Regards,
Paulo.
Old 2nd March 2012, 02:48 PM   #2038
Salas's Avatar
Only laterals. What Nico showed are real values biasing real parts. Those which worked best in LT Spice are biasing models. Shows how sensitive it is non the less, because those values I gave for the good sim aren't really far. You got to see when hands on and use trimmers on crucial ones until you set it right as I said. Those are just my general opinions trying to help out though, I am not Nico and maybe the right answers are different, remember. In general this is a practical thing. You make it, you evaluate bias and stability on your layout, you try for good offset. You gotta have generator and scope absolutely. Not recommended as novice's project. If in doubt, get official boards and make F5, next of kin best thing. Just my plan B suggestion if things go wrong, not trying to disappoint you.
Old 2nd March 2012, 03:24 PM   #2039
You're not disappointing me, I thank you for your advice.
This is an interesting thread. I'll be following it and when a final stable design is achieved I'll build it.
Thanks.
Kind Regards,
Paulo.
Old 2nd March 2012, 04:41 PM   #2040
Nico Ras is online now Nico Ras  South Africa
Nico Ras's Avatar
Hi PaulPT,
There is no absolute GO/NO-GO condition in analogue electronics and tweaking practically is more often than not the final stage of the design. Besides, I think that DIY audio guys (myself included) places far too much emphasis on harmonic plots from simulators.
It is possible to optimise every component using a simulator and get really silly numbers. Problem is one eventually believes that it will be the actual performance of the product - it never is.
I am still using my lazy cat to this day, everyday in my office. Even with the assumed high level of simulated distortion, its sound remains absolutely magic.
Kindest regards
Nico
Simple Symetrical AmplifierHide this!Advertise here!
Symetrical schematics are alike plague in Brazil, do you like them? destroyer X Solid State 151 1st July 2010 02:09 PM
Symetrical out low Zout karsten21 Tubes / Valves 5 1st February 2010 10:19 PM
going balanced/symetrical - what benefits? weissi Solid State 15 20th October 2007 08:06 AM
Symetrical field, is this? Raka Multi-Way 6 14th September 2003 01:21 PM
Non-symetrical SMPS output cm961 Parts 4 21st August 2003 10:27 PM
