Simple Symetrical Amplifier - Page 2 - diyAudio
Old 3rd August 2011, 01:23 PM   #11
juma is offline juma  Germany
juma's Avatar
Maybe it wouldn't be a bad idea to add one small pot to control the DC offset at the output...
Old 3rd August 2011, 01:50 PM   #12
Lazy Cat's Avatar
Actually we can make offset control, simply by changing 1k resistor closest to BF471 into multi-turn trimmer. Current imbalance (Hfe & Ube difference of the input pair) causing offset would be elegantly compensated in that way
Old 3rd August 2011, 02:01 PM   #13
Lazy Cat's Avatar
Originally Posted by MarianB View Post
Correct me if i'm wrong but i think we are not always looking for perfection when building an amp, sometimes we need a simple low cost low power amp and this one looks just fine i think
I agree completely. But my intention and priority is always sound quality and musicality (enjoyment factor at listening), since that is hardly achievable from complex designes. I stoped built complicated ones cause complexity/musicality factor raise exponentialy.
Old 3rd August 2011, 02:58 PM   #14
This looks quite interesting and indeed, very simple. What's the power ? And could someone post a schematic for the power supply (for a beginner such as I ).
Old 3rd August 2011, 03:09 PM   #15
MarianB is offline MarianB  Romania
MarianB's Avatar
Send a message via Yahoo to MarianB
Well i presume the power would be something like 30 or 40W on a 4Ohm load, but that is just an asuption, if i'm wrong than i apologise and ask to be corrected.
As for the power supply, well it would have to be something like this:
The filter caps should be arround 10.000u at the proper voltage rating, you could add 2 power resistor in paralel with the caps for discharge purpose, as well as 2 ceramic or poliester 100n capacitors in paralel as well with the big ones, to compensate for high frequencyes.
Old 3rd August 2011, 03:33 PM   #16
Lazy Cat's Avatar
@Dmeister
If we asume that +/- 35 V rails potential is stable (maybe even regulated) than we could easily achieve 50 Wrms/8 ohm (3,53 Ap) or even 75 Wrms/4 ohm (6,12 Ap). I would also recommend to set high quiescent current, at least 200 mA through output mosfets.
Old 3rd August 2011, 03:49 PM   #17
Parasonic's Avatar
Very nice Lazy Cat.............
Are you listening to a single channel, or do you have a stereo setup?
Terry
Melody, harmony, timbre, rhythm
Old 3rd August 2011, 04:10 PM   #18
Lazy Cat's Avatar
Manage to put together one channel, both will be ready soon. Nevertheless mono listening test showed its serious potential to be a good sounding amp. Presented dynamics and vocal authentics just astonished me.
Old 3rd August 2011, 05:00 PM   #19
Bigun is offline Bigun  Canada
Bigun's Avatar
A nice project - DIY at it's best !
p.s. This design reminds me mostly of Hiraga's Le Monstre with a touch of F5 ?
File Type: png Hiraga-Monstre-Monster-Class-A-amplifier-schematic.png (31.2 KB, 4217 views)
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 3rd August 2011, 11:43 PM   #20
Lazy Cat's Avatar
I see So nothing new on the planet Earth, just fun continous
Symetrical schematics are alike plague in Brazil, do you like them? destroyer X Solid State 151 1st July 2010 02:09 PM
Symetrical out low Zout karsten21 Tubes / Valves 5 1st February 2010 10:19 PM
going balanced/symetrical - what benefits? weissi Solid State 15 20th October 2007 08:06 AM
Symetrical field, is this? Raka Multi-Way 6 14th September 2003 01:21 PM
Non-symetrical SMPS output cm961 Parts 4 21st August 2003 10:27 PM
Copyright 1999-2017 diyAudio
