#1601 | |
EDIT: another driver stage can be added if the above is not optimum. Last edited by Jay; 3rd December 2011 at 04:57 PM. |
#1602 |
I concider the input and cascode as one device, one better device, I would put them back in...
and I would add a jfet as a current scouce in the vas stage to revent thermal current drift Last edited by MiiB; 3rd December 2011 at 05:34 PM. |
#1603 |
Hi Jay
Yes, MiiB has the point here but if you still insist to omit cascodes than you shoud do it in a right manner. Input pair without cascodes will of course work if you'll choose low noise, high Vce (65 V or more) transistors like BC546B/BC556B, 2SA970/2SC2240 or similar. No input cascodes also mean higher power dissipation on input pair so no more than 2 mA collector bias current is recommendable (Rc 330 ohm). Instead of 820 ohm resistor I suggest you to use simple Vbe multiplier completely installed on a PCB to act as adjustable zener only. It will provide you more stable output DC bias conditions as being independent to VAS thermal bias fluctuations. Otherwise this version will work nicely also with lower rails potential like +/- 35 V and will easily give you 50 Wrms/8 ohms, since 28,28 Vp is exactly the figure you need for that kind of output power.
#1604 |
Yes a vbe...not mounted on a heatsink....or a jfet currenscouce in series with the bias spread resistor..
#1605 | ||
TO-92 is fine for the cascode but in the schematic posted by LC lately it was BF470. Without it, if ever possible (acceptable measured performance/stability), it will sound better I believe. Quote:
BTW, how about your SSA MOSFET with 60V rail, are they safe? I have just lost 4 pairs laterals already
#1606 | |
For the worse noise rejection without the cascode, my plan was to use regulated supply for the front end including the driver (so only the laterals use classic supply). This way, the FET regulator may be compared with simple RC filters. The higher voltage was not primary for power. I just think the mosfet will need them. |
#1607 |
The thing is that the drivers increase current when they and the input stage heat up...this can be avoided with the use of the jfet ccs ( as per suggested by salas)...then yuor laterals won't run away
#1608 | |
How about small fan (I have 3x3cm) on top of the BJT drivers, with adjustable speed, or speed that change with temperature sensing as found in computer power supplies
#1609 |
Your right about the fets....but what about the VAS/drivers...?. When they heat up the current increases and thus the sprread increases
#1610 | |
What is the maximum power (and supply rail) can be had from both circuits? I believe the cascode will bring more benefit (or is it a must) when higher supply rail is used in such a simple circuit. I will use at least 46V rail (preferably more) and 2 output pairs. I expect at least 70W to replace my Goldmund clone (Mimesis 3) and I want to start with the simplest circuit, i.e. Ruwe version (because I believe the simplest SSA wont make it there). I guess Ruwe circuit is not optimal but very potential soundwise. But if this circuit cannot give comparable power to Mimesis 3, I will start with my previous idea, or add another driver, i.e. Wahab's schematic without the input cascode. |
| Symetrical schematics are alike plague in Brazil, do you like them? | destroyer X | Solid State | 151 | 1st July 2010 02:09 PM |
| Symetrical out low Zout | karsten21 | Tubes / Valves | 5 | 1st February 2010 10:19 PM |
| going balanced/symetrical - what benefits? | weissi | Solid State | 15 | 20th October 2007 08:06 AM |
| Symetrical field, is this? | Raka | Multi-Way | 6 | 14th September 2003 01:21 PM |
| Non-symetrical SMPS output | cm961 | Parts | 4 | 21st August 2003 10:27 PM |
