Old 28th November 2011, 10:34 PM   #1541
Lazy Cat's Avatar
Originally Posted by tinitus View Post
as per the 3U 133mm rack size standard, modushop appear to measure their entire box brutto height, and thus internal height is only 120mm
but doesnt matter when there is a 4U
Now you know why PCB is 120 mm, notoriously standard dimension in pro-audio.
Old 28th November 2011, 10:41 PM   #1542
Lazy Cat's Avatar
Originally Posted by Idefixes View Post
ARGGGG double side pcb board....a pity to etch at house....so it seems that i need to spend many time on eagle for sigle side way.... with more room needed. LC i suppose that BIGBT HP in lowaer rail voltage count same parts number as your hightest version...only value changing inside????
Marc
Note : NJL4302DG arrived today so yet i have 5 couples NJL4281DG/4302DG for SSA_TT_35V
I am sorry for that my PCB version is inappropriate for you, but it is mine version and suited strictly to my needs and expectations. Schematic of it was published, so anyone can design a PCB exactly to his own taste, you're welcome too.
Yes, only the values will be recalculated later on.
Old 28th November 2011, 10:50 PM   #1543
Lazy Cat's Avatar
Originally Posted by sonnya View Post
It is only a suggestion. Move the el-caps a bit away and place polyprop caps close instead.
... place polyprop caps close instead.
Cannot do closer than 3 mm from rails split to the outputs.
El-caps does not go higher than a few hundred kilohertz. The film caps stretches to around a few megahertz.
mhhmm ... I wonder mhmm ... and mica to few hundreds ... mhmmm thanks anyway
Old 28th November 2011, 11:17 PM   #1544
Bigun is offline Bigun  Canada
Bigun's Avatar
Hugh found same thing on one of his amplifiers.
The big electro's can be some distance away. In my first amplifier I placed them all in the chasis and none on the amplifier board. With short distance wiring this works just fine. It keeps them away from the heat of the power devices too not to mention less mechanical stress if they aren't hanging sideways off a board.
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 29th November 2011, 06:26 AM   #1545
Idefixes's Avatar
Send a message via ICQ to Idefixes
Don't be sorry. The value recalculation to my 50/60V rail is more than i can askinng from you. As i am not able on electronic amp design....pcb board making, internal and external architecture/design is the way i made a DIY project mine. Than if some provide a fonctionnal schematic with my requierement i am more than happy.
Marc
Edit : I just look what sort of standart Pcb board are available and could match with the goal. There is a 150x200mm; i will try to do with this.
website : http://audiyofield.wifeo.com/index.php
Old 29th November 2011, 09:24 AM   #1546
Lazy Cat's Avatar
... and the components layout is about 95% finished. Some minor changes will take place on the way by routing the traces.
It is definitively not the PCB for the faint hearted DIY-ers.
Old 29th November 2011, 09:52 AM   #1547
Any chance to listen this beast?
Old 29th November 2011, 10:02 PM   #1548
alex mm is offline alex mm  Europe
alex mm's Avatar
..... PCB ready, size 170 mm X 120 mm , but not symetrical layout
Alex.
Old 29th November 2011, 10:07 PM   #1549
tinitus is offline tinitus  Europe
hey, looking great
hmm, I wonder if it also would be a good realiable bassguitar power amp
why 100V caps ?
Old 29th November 2011, 11:08 PM   #1550
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Andrej, what will be the 8 Ohm RMS power?
Symetrical schematics are alike plague in Brazil, do you like them? destroyer X Solid State 151 1st July 2010 02:09 PM
Symetrical out low Zout karsten21 Tubes / Valves 5 1st February 2010 10:19 PM
going balanced/symetrical - what benefits? weissi Solid State 15 20th October 2007 08:06 AM
Symetrical field, is this? Raka Multi-Way 6 14th September 2003 01:21 PM
Non-symetrical SMPS output cm961 Parts 4 21st August 2003 10:27 PM
Copyright ©1999-2013 diyAudio
