Simple Symetrical Amplifier
Old 28th November 2011, 07:13 PM   #1531
Idefixes is offline Idefixes  France
Idefixes's Avatar
Send a message via ICQ to Idefixes
LC you are a master in amp ingeniering .....but a master in.......teasing too......
Marc
website : http://audiyofield.wifeo.com/index.php
Old 28th November 2011, 07:23 PM   #1532
Lazy Cat is offline Lazy Cat  Slovenia
Lazy Cat's Avatar
Originally Posted by tinitus View Post
120mm fits perfekt in a modu 4U/300 with 165mm internal height, giving a nice chunky look
and those heatsink should make it indestructable in any load
It can be nicely installed in 3HU (132 mm) as side external heatsinks as well. 120mm x 170 mm SSA BIGBT HP PCB plus 400VA/120 mm (diameter) x 80 mm toroidal transformer, fits perfectly on a 132 mm x 300 mm x 40 mm Fischer heatsink as compact all-in-one amplifier module.
Old 28th November 2011, 07:33 PM   #1533
sonnya is offline sonnya  Denmark
sonnya's Avatar
Originally Posted by Lazy Cat View Post
... and just for a comparison, the one (too big for me) who's gonna be developed further by Alex. I wonder mhmm
Try to get you solderiron down between the caps to solder the power transistors/mosfets!
I go for Alex... Sorry Lazy cat
Old 28th November 2011, 07:52 PM   #1534
Lazy Cat's Avatar
OK as you wish, but all the bigs caps are soldered at the end of construction, when all other components are already installed. All under PCB BJT's must be mechanically fixed to flat firm surface and than soldered to PCB, after low profile components (diodes, LEDs resistors, etc.). SSA "construction work" (installation) manual will follow.
It all depends on priorties one demands to follow. Major one ahead of this design here is to maintain high bandwidth results from protoboard measurements. It will be PITA to get there but anyway ...
P.S. This will be double sided PCB and big caps are 50 mm height.
Old 28th November 2011, 08:38 PM   #1535
alex mm is offline alex mm  Romania
alex mm's Avatar
...... Andrej can you show as the layout of yours ? I can
Old 28th November 2011, 08:38 PM   #1536
Lazy Cat's Avatar
Marc
Tnx hehehe I know ... the more fun the better results
Old 28th November 2011, 08:44 PM   #1537
Lazy Cat's Avatar
Ooooh nice try Alex, outputs in the middle, splendid
But my demand is max. PCB dimensions of 120 mm x 170 mm because of the standard heatsink size 300 mm and beside PCB also to accomodate 400VA transformer on it.
Old 28th November 2011, 08:51 PM   #1538
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
ah, ok, I didnt know this
though, seems there are still room fore 'interpretations'
as per the 3U 133mm rack size standard, modushop appear to measure their entire box brutto height, and thus internal height is only 120mm
but doesnt matter when there is a 4U
Old 28th November 2011, 08:53 PM   #1539
Idefixes's Avatar
ARGGGG double side pcb board....a pity to etch at house....so it seems that i need to spend many time on eagle for sigle side way.... with more room needed. LC i suppose that BIGBT HP in lowaer rail voltage count same parts number as your hightest version...only value changing inside????
Marc
Note : NJL4302DG arrived today so yet i have 5 couples NJL4281DG/4302DG for SSA_TT_35V
Old 28th November 2011, 09:11 PM   #1540
sonnya's Avatar
It is only a suggestion. Move the el-caps a bit away and place polyprop caps close instead.
El-caps does not go higher than a few hundred kilohertz. The film caps stretches to around a few megahertz.
Simple Symetrical AmplifierHide this!Advertise here!
Symetrical schematics are alike plague in Brazil, do you like them? destroyer X Solid State 151 1st July 2010 02:09 PM
Symetrical out low Zout karsten21 Tubes / Valves 5 1st February 2010 10:19 PM
going balanced/symetrical - what benefits? weissi Solid State 15 20th October 2007 08:06 AM
Symetrical field, is this? Raka Multi-Way 6 14th September 2003 01:21 PM
Non-symetrical SMPS output cm961 Parts 4 21st August 2003 10:27 PM
