Simple Symetrical Amplifier - Page 153 - diyAudio
Old 28th November 2011, 02:38 AM   #1521
mikelm is offline mikelm  England
Send a message via Yahoo to mikelm
Originally Posted by cats squirrel View Post
Hi Marc
nichrome wire is made of Nickel and Chromium, and has a relatively high resistivity, and therefore resistance, depending on diameter.
Look here for typical values: wires.co.uk : Bare Nickel Chrome / Nichrome Section
I have had good results with Costantan wire which has a better TC than NiCrome - this wire sounds better that any commercially available resistors I have tried. Ideal for low values. I have been using this wire in my amps as o/p degeneration & o/p resistors / fuses for years.
wires.co.uk : Copper Nickel / Constantan / Eureka Section
But I am informed that manganin is considered better that constantan: even lower TC and also much less nickel in the mix and thus less "magnetic" but I didn't try it yet.
WIRES.CO.UK MANGANIN
Old 28th November 2011, 06:51 AM   #1522
AKSA is offline AKSA  Australia
Mike,
Can you solder these special wires?
Hugh
Aspen Amplifiers P/L (Australia)
www.aksaonline.com
Old 28th November 2011, 07:59 AM   #1523
Hi Hugh,
I have done a long term chemical analysis ( I would not know how ) but the Constantan wire seems to solder without problems - Havn't used my Manganin yet
Old 28th November 2011, 08:51 AM   #1524
Banned
They are Copper alloys. But i wonder about thermal dissipation and corrosion ?
Old 28th November 2011, 09:00 AM   #1525
My coils of constantan are more than 5 years old and the appearance has not changed in that time.
Old 28th November 2011, 01:24 PM   #1526
SOUND_Rays's Avatar
NAIM uses same solution for years
Old 28th November 2011, 02:09 PM   #1527
seems like a nice project for someone, there!
My partner uses nichrome wire as elements in her kiln, which has been up to 1100C and back again virtually every other day for ten years without problem!
Old 28th November 2011, 03:12 PM   #1528
Nico Ras's Avatar
Our company has used it as shunt (load-sensing) resistors for 50 years. Nickel/chrome does not corrode and can be soldered. The wire resistor will outlast the solder joint.
Kindest regards
Nico
Old 28th November 2011, 06:47 PM   #1529
Lazy Cat's Avatar
Interesting events development, Alex didn't accepted my board proposal (too densely populated), so it looks we will have the SSA BIGBT HP PCB design competition here hehehe.
Lots of fun ahead yeah.
Old 28th November 2011, 07:08 PM   #1530
Lazy Cat's Avatar
... and just for a comparison, the one (too big for me) who's gonna be developed further by Alex. I wonder mhmm
Symetrical schematics are alike plague in Brazil, do you like them? destroyer X Solid State 151 1st July 2010 02:09 PM
Symetrical out low Zout karsten21 Tubes / Valves 5 1st February 2010 10:19 PM
going balanced/symetrical - what benefits? weissi Solid State 15 20th October 2007 08:06 AM
Symetrical field, is this? Raka Multi-Way 6 14th September 2003 01:21 PM
Non-symetrical SMPS output cm961 Parts 4 21st August 2003 10:27 PM
Copyright 1999-2017 diyAudio
