Simple Symetrical Amplifier
Old 26th November 2011, 07:01 PM   #1501
Idefixes is offline Idefixes  France
Idefixes's Avatar
Send a message via ICQ to Idefixes
Originally Posted by Esperado View Post
May-be this can reduce a little distortion. (see around output)
Hi Christophe, you mean reducing the trace size the feeding feedback resistor from Output point?
Marc
Edit : May be something like this attached
website : http://audiyofield.wifeo.com/index.php
Old 26th November 2011, 07:10 PM   #1502
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
it looks very nice
but are you sure its good to place your most sensitive curcuit right the middle of your high power supply
well, basicly its just the two rectifier bridge that bothers me
but maybe its ok
I cant see the input connection ?
but strangely, lately I see more and more members place the output devices in a way that doesnt seem to make very good use of the heatsink
and even the most experienced ones
things like having outputs at the very top of a heatsink
and I really hate when you cant turn a board 180degr, without ending up with long wires etc
sometimes its like only designing a board fore the left channel, and forgetting how both channels look when mounted
stuff like power supply connection, signal wires etc
seems like a matter of not having patience and time to think it all through, very carefully
why such hurry ?
btw, I do like that your board looks different than usual
its 'refreshing', and good thinking
Old 26th November 2011, 07:15 PM   #1503
sonnya is offline sonnya  Denmark
sonnya's Avatar
Originally Posted by Idefixes View Post
Sonnya excuse me for my sad electronic knowledge, could you explain more what you mean?
Marc
You should not excuse!!! We All have to start somewhere...
In my experience, the VAS stage in this AMP changes a lot in the warmup process. So you need a constant voltage source instead so that you Can get a stable idle current
Old 26th November 2011, 07:27 PM   #1504
Idefixes's Avatar
Originally Posted by tinitus View Post
it looks very nice
but maybe its ok
why such hurry ?
The PCB board will be place in the same orientation as in picture below (Input is in orange underlined). In the way of implamentation the output devices will be place in the first 1/3 from the heatsink bottom. The Heatsink fines will be verticaly oriented.
Old 26th November 2011, 07:28 PM   #1505
btw, with cooler classAB, it would work nice mounting supply board vertically at one end of your heatsink
and please, look at size of available amp box design, height of heatsink, etc
Old 26th November 2011, 07:33 PM   #1506
them are prefect
but why not place bridge and caps 'below' them, opposite input ?
that way you would have supply line nicely placed close to bottom, and not flapping up in the upper half of your box
Old 26th November 2011, 07:42 PM   #1507
Idefixes's Avatar
Tintinus,
I attached 3 internal sketch from what i have in mind : the first is a rear view, the second a front view with trafo in orange, the third a side view.
All what i built are DIY case. Dimension and configuration are always dicted by internal configuration. PSU section is in the upper parts of the board because Trafo is in taht same area on other heatsink side separated by a 2mm thick steel sheet.
Old 26th November 2011, 07:57 PM   #1508
Esperado is offline Esperado  France
Banned
No, the larger, the better. I mean keeping voltage (or current) to the feedback resistor coming right from the output pin and only from there.
Tracks are not 0 ohms and at those currents, you can see differences in signals from different points.
Old 26th November 2011, 08:26 PM   #1509
Idefixes's Avatar
Ok thanks for advice. I modify the layout this way
Old 26th November 2011, 08:40 PM   #1510
Tintinus,
ah, that is different, and clever
it is really very effective to have the heatsink go through bottom and top
I have experienced problems when having trafo close to input
but I guess your heatsink shields it nicely
Simple Symetrical AmplifierHide this!Advertise here!
Symetrical schematics are alike plague in Brazil, do you like them? destroyer X Solid State 151 1st July 2010 02:09 PM
Symetrical out low Zout karsten21 Tubes / Valves 5 1st February 2010 10:19 PM
going balanced/symetrical - what benefits? weissi Solid State 15 20th October 2007 08:06 AM
Symetrical field, is this? Raka Multi-Way 6 14th September 2003 01:21 PM
Non-symetrical SMPS output cm961 Parts 4 21st August 2003 10:27 PM
