#1401 |
#1402 | |
P.S. Hehehe one day you will ...
#1403 | ||
diyAudio Chief Moderator
#1404 | |
, a 4.way system? For the sub You also use the SSA High Perf. same as for main speakers? Vinyl playback on Yours system is perhaps sounding outstanding? - For really comfortable driving 2.5 OHm speakers, how many BIGBT modules would be necessary? ![]() Kind regards, |
#1405 |
Hi everyone,
Is there a variation of this amp that can be used to drive headphones? Thanks Ryan |
#1406 |
But, the CCS in the VAS means that this is no longer a symmetrical VAS. It controls the current through one side of the VAS well, but leaves the other side more room to move with temperature. It's asymmetric, a different amplifier.
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig. |
#1407 | |
#1408 |
For TO-126 at that power level (2mA or up to 10mA across 30V) don't expect much thermal wandering. Was moving around much more without. Its a solution for when some versions won't behave.
#1409 |
SSA BIGBT HP front-end initial power-up, stability check and some measurements.
Prior to full power testing with complete circuit (BIGBT power outputs) I checked what can I expect from SSA High Performance front-end plus power mosfet drivers. SSA input bias set to 2,5 mA, VAS bias 15 mA, drivers bias 50 mA. Offset trimmed to zero and it was inside +/-20 mV all the measurement time with no instability issue. Bias of the drivers was completely thermally stable. Than AC measurements took place and here are the results: - output impedance 38 mohms, tested at 1 A/4,7 ohm load - 1 ohm stable (drivers as output devices) inside SOAR - bandwidth -3 dB unmeasurable with my current equipment - input/output phase delay 12 ns at 2 MHz (period 500 ns), that is equivalent of 8,6° phase shift I was satisfied with initial testing, so we have a go for further development.
#1410 |
Very nice. Will you do FFT on some computer card loop also? In which one specific schematic is the build referring to?
| Symetrical schematics are alike plague in Brazil, do you like them? | destroyer X | Solid State | 151 | 1st July 2010 02:09 PM |
| Symetrical out low Zout | karsten21 | Tubes / Valves | 5 | 1st February 2010 10:19 PM |
| going balanced/symetrical - what benefits? | weissi | Solid State | 15 | 20th October 2007 08:06 AM |
| Symetrical field, is this? | Raka | Multi-Way | 6 | 14th September 2003 01:21 PM |
| Non-symetrical SMPS output | cm961 | Parts | 4 | 21st August 2003 10:27 PM |
