Simple Symetrical Amplifier - Page 135 - diyAudio
Old 7th November 2011, 08:59 PM   #1341
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Nice Andrej, but K170 & J74 tend to positive TC in my experience when selecting them for IDSS. Also high Ciss. I have in hand a few BF245C and BF245B. Tested them, 10mA ones they go lower current about 0.3 mA relatively fast when left on 9V battery in G&S shorted IDSS mode. The delicate part is to find some already near target, because the source resistor (or trimmer) slows down the -TC time as I have seen with 100R. A 10mA one goes 7.7mA and moves negatively slower for just 0.1mA. Nice is that the C are almost 15mA all of them and the B are 7mA and 10mA groups. So a small trimmer can just hold the 10mA ones to trim around 8mA centre. We don't need PJFET, we can orient drain of NJFET towards the input transistor and keep them same die characteristics. Now if the steady current will be the main stabilizing force and not the supplementary TC tendency, maybe we can use many different JFET types and trimmers. Remains to be seen in practice. Soon.
Old 7th November 2011, 09:24 PM   #1342
Lazy Cat's Avatar
Yes, I agree, it can be N channel j-fet only but it was so tempting to put complementary ones in the schematic hehe. Small Rgs resistance will do the job, so BF245B will be the right one to suit the need.
Old 7th November 2011, 09:42 PM   #1343
Sheldon is offline Sheldon  United States
DN2540?
http://www.supertex.com/pdf/datashee...upertex.com%22
Old 7th November 2011, 09:50 PM   #1344
Salas's Avatar
Thought of them, I have 5 matched pairs and about 20 random pieces, but see the Ciss. 300pF VS 4pF of the BF245. And this is an amp we like to keep fast. They also need gate stoppers that will build on time constant. Nicely -TC non the less.
Old 7th November 2011, 10:06 PM   #1345
Banned
Sometimes, aesthetic of the schematic can provide benefits to the sound. I understand-you well. Harmony is the target.
I mean, every *love* or pleasure you bring in a work will be given back a way or an other. Reason why no computer can design a "musical" power amp, neither a good text translation ;-)
More than that, under some reptilians reflexes we can have, we can discover sometimes some hidden intuitive and not analyzed knowledge witch will go to the surface later.
That makes the differences between our works, can bring to new ideas...
Well, i use to make symmetrical passive filters for my speakers. It first look stupid as it cost more components. it makes a difference, i tried to explain and now, i understand why and stay on it.
Old 7th November 2011, 10:24 PM   #1346
Bigun is offline Bigun  Canada
Bigun's Avatar
Originally Posted by Ruwe View Post
I had to discard the use of vertical MOSFETS and BJTs, because of their high temperature drift. I can assure you that I've spent hundreds of hours (I'm not exaggerating) and tried many output configurations. None of them had stable quiescent current and no modification or change in the schematic values gave me reliable results.
Ruwe, Apart from the unruly idle current how bad was the dc offset stability ? - did you physically tape together the two input devices ?
Thanks.
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 7th November 2011, 10:55 PM   #1347
Salas's Avatar
... If this solution would prove to be adequate, than you can simply omit j-fet from your VAS stage.
It will mean asymmetric cascode load resistors (need be trimmers). It will shoot fast the output Iq one way or opposite polarity if steady same resistors. Much as Ruwe had. Latfets have no symmetric Vgs and as the thing changes tempco current difference in the bridge branches it takes 4 hands to trim fast. In practice the drivers common bias CCS kicks at about 150mV minus that homogenizes in the Latfes Vgs bracket enough.
Old 7th November 2011, 11:35 PM   #1348
Does the speed really matter for a current source here?
Sheldon
Old 7th November 2011, 11:49 PM   #1349
Salas's Avatar
Not sure. Intuition. At least not as good as a 4pF one for CCS PSRR. Choosing to test with the BF because I have both. Against DN price, rarity in Europe, size, big resistor to get down the Idss, probably noisier as Mosfet VS Jfet... But for basic current stability test it will do it too. As LM334 will and other we may have.
Old 8th November 2011, 12:28 AM   #1350
My question of speed was based on weak intuition. I guess that gate to source capacitance would affect high frequency PSRR. At lower frequencies PSRR would be just a function of transconductance? I asked about the DN part, as I have a bunch here (TO92 versions, so size not an issue). Would we bond these thermally to the input devices?
Sheldon
Symetrical schematics are alike plague in Brazil, do you like them? destroyer X Solid State 151 1st July 2010 02:09 PM
Symetrical out low Zout karsten21 Tubes / Valves 5 1st February 2010 10:19 PM
going balanced/symetrical - what benefits? weissi Solid State 15 20th October 2007 08:06 AM
Symetrical field, is this? Raka Multi-Way 6 14th September 2003 01:21 PM
Non-symetrical SMPS output cm961 Parts 4 21st August 2003 10:27 PM
Copyright 1999-2017 diyAudio
