Simple Symetrical Amplifier - Page 130 - diyAudio
Old 5th November 2011, 06:06 PM   #1291
Bigun is offline Bigun  Canada
Bigun's Avatar
Originally Posted by Jay View Post
... even tho bipolar sound is not my cup of tea.
do you really believe bipolar has a 'sound' ? I thought that the topology and operating points and power supply are going to have a bigger impact on the sound than choice of FET verses BJT - although I haven't the experience you have, I thought that both of them can be employed to achieve the results you are looking for.
... the SSA is simple and perfect physically.
I have this strange irrational feeling that really good amps are imperfect in some way - technically speaking that is. It's part of the 'Art' as you have said
The SSA has it's weaknesses - thermal stability is one of them - in my opinion, and use of zeners (noisy things). And I think it will sound better if it's NOT actually symmetrical - an easy thing to achieve and I hope to try this out with my TGM5 version.
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 5th November 2011, 06:16 PM   #1292
Nico Ras's Avatar
I would just like to ask, off-set is measured with reference to what? Obviously 0V reference which is dictated by the power supply. If the positive rail caps are slightly more leaky than the negative rail, or if the transformer windings are a few mV difference which is very likely, you are actually offsetting your amp deliberately to compensate for the power supply.
When the signal is applied and the one rail drops in relation to the other, won't there be an immediate dc offset besides the signal. You all talking DC states, you don't listen to DC do you?
Kindest regards
Nico
Old 5th November 2011, 06:18 PM   #1293
apassgear's Avatar
Hi Salas
We might be looking for similar results on an amp, I too find the need for some help in the lower region that the F5 can't deliver fully at least with my speakers.
Are you planning to parallel output devices at the end?
Tony
Old 5th November 2011, 06:58 PM   #1294
Sheldon is offline Sheldon  United States
Originally Posted by Lazy Cat View Post
Guys, no worries please, you can always do something like this.
If I have a single output pair for the FC100 buffer, can I do thermal comp. like this? I've left out stoppers and bypass caps for simplicity of display. The 1N diodes are standard small signal diodes, the ones labeled NJL are the Thermatrak diodes.
Old 5th November 2011, 07:04 PM   #1295
Nico Ras's Avatar
Apassgear,
No disrespect intended, I always get a little concerned by power nuts. It is always a good measure to make the SSA as it was intended, familiarize yourself with it quirks, shortfalls and advantages, and most importantly get a feel for its sound whether it lives up to your expectation before pouring a bucket of transistors into it.
It is relatively easy to expand when you are satisfied that it is the amplifier that you want to live with.
Kindest regards
Nico
Old 5th November 2011, 07:13 PM   #1296
Nico Ras's Avatar
Sheldon, that method is feasible. It will compensate for ambient as well using it like you indicate.
Kindest regards
Nico
Old 5th November 2011, 07:15 PM   #1297
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
No problem if the DC values will stay at safe margins in the long run. For the time being this amp can easily give me the creeps some times during on off eratically. Building another channel now to see if its a trend or an error.
Old 5th November 2011, 07:17 PM   #1298
Salas's Avatar
Originally Posted by apassgear View Post
Hi Salas
Tony
Don't know, got to listen to it critically first when I will have a satisfactory stereo build on hand, hopefully soon.
Old 5th November 2011, 07:33 PM   #1299
sonnya is offline sonnya  Denmark
sonnya's Avatar
I have a solution to the drift...
1. You Can use it or not. The 2 input transistor should be feed by an current mirrors feed by a shared currentsource Like cr200..
2. the cr200 Will give an idle current of 2mA +/-10%.. this Will reduce the basiscurrent and remove the heat. The baseresistor for the next stage has to be 5x larger..
This solution is taken from my mirand AMP.
I have a drift starting at 300mV falling to ~50mV. And i Will ADD the circuit above
Old 5th November 2011, 07:38 PM   #1300
Lazy Cat's Avatar
Maybe it is a possible error or unsymmetry caused by the fet current source because of its voltage drop ...
Mine SSA BIGBT has no power on thump-pop whatsoever (scope shows 200mV positive jump for the first 0,2 s for no loaded amp) and its thermal DC offset drift inside +/-10 mV over cold to 70°C.
More important issue is an output bias thermal stabilization which can be realized successfully in many ways, already suggested here and in TGM5 thread, how to hold the amp at a certain thermal working conditions.
According to my oppinion the most important feature by this design is its no frequency compensation need as a result of the SSA feedback nature and consequently the sound quality result.
Symetrical schematics are alike plague in Brazil, do you like them? destroyer X Solid State 151 1st July 2010 02:09 PM
Symetrical out low Zout karsten21 Tubes / Valves 5 1st February 2010 10:19 PM
going balanced/symetrical - what benefits? weissi Solid State 15 20th October 2007 08:06 AM
Symetrical field, is this? Raka Multi-Way 6 14th September 2003 01:21 PM
Non-symetrical SMPS output cm961 Parts 4 21st August 2003 10:27 PM
Copyright ©1999-2017 diyAudio
