Simple Symetrical Amplifier
Old 9th August 2011, 03:17 PM   #121
Nico Ras is offline Nico Ras  South Africa
Nico Ras's Avatar
Some other research papers show that 180 mA for 2SK1058 and 2SJ162 as output devices indicates least distortion.
For the last requirement would of course require Vbe multiplier, in the current circuit it is not necessary. I have designed with MOSFET driving BJT but thermally it has never been stable without it. What are your suggestions.
Old 9th August 2011, 03:25 PM   #122
Nico Ras's Avatar
With BJT following MOSFET distortion seems significantly worse. Maybe you have some clues.
Old 9th August 2011, 03:29 PM   #123
Nico Ras's Avatar
Freq response remains good.
Old 9th August 2011, 03:30 PM   #124
Lazy Cat is offline Lazy Cat  Slovenia
Lazy Cat's Avatar
I know, look to my pic of my test bench, and there it is, Vbe multiplier sitting on the top of BIGBT. I know it is one more transistor in sch, but it works perfectly. As I metioned before, the BIGBT temperature went well over 60C, because of the signal present on 6 ohm load at the output (no thermal runaway) without any heatsink, and bias current was still perfectly stable.
Maybe we should first simulate:
- BJT driver/mosfet output
- mosfet driver/BJT output
to see which combination sounds the best and than we can surely decide about the need of Vbe multiplier.
Old 9th August 2011, 03:32 PM   #125
Nico Ras's Avatar
I think we are writing at the same time.
Old 9th August 2011, 03:33 PM   #126
Nico Ras's Avatar
I will change my spiders web, and listen, it will take a while and I only have MJ15001 and MJ15002 available right now.
Old 9th August 2011, 03:37 PM   #127
Lazy Cat's Avatar
OK, I heard the second combination and I just love it.
Please rearrange your spider and than report, enjoy Nico.
Old 9th August 2011, 03:49 PM   #128
Lazy Cat's Avatar
I see an even harmonics much more present in distortion distribution than odd ones, maybe this is the reason why the amp sounded very pleasant. The average level can be lowered significantly by proper biasing of both stages.
Old 9th August 2011, 03:55 PM   #129
Nico Ras's Avatar
It will take me a while to drill heat sinks and unravel the crows nests before I can try listening again. Now I have to divert my efforts to cooking instead of simulating :-)
Old 9th August 2011, 05:33 PM   #130
bogdan_borko is offline bogdan_borko  Serbia
bogdan_borko's Avatar
Originally Posted by Lazy Cat View Post
Thanks Hugh, it is purely my idea.
It`s a Hawksford LFD preamp concept, but nice circuit anyway.
http://www.essex.ac.uk/csee/research...D%20preamp.pdf
Svakog dana u svakom pogledu sve manje nazadujem.
Simple Symetrical AmplifierHide this!Advertise here!
Symetrical schematics are alike plague in Brazil, do you like them? destroyer X Solid State 151 1st July 2010 02:09 PM
Symetrical out low Zout karsten21 Tubes / Valves 5 1st February 2010 10:19 PM
going balanced/symetrical - what benefits? weissi Solid State 15 20th October 2007 08:06 AM
Symetrical field, is this? Raka Multi-Way 6 14th September 2003 01:21 PM
Non-symetrical SMPS output cm961 Parts 4 21st August 2003 10:27 PM
