Simple Symetrical Amplifier - Page 104 - diyAudio
Old 2nd October 2011, 08:06 PM   #1031
Lazy Cat's Avatar
Originally Posted by AndrewT View Post
Testing hFE at constant Ic is a little more consistent than using constant Ib.
I always use constant Ic now, for hFE measurement even though I don't know Tj.
Multimeters, with a give away for free hFE tester built in, generally use constant Ib.
They are no better than a batching tool. The problem is that one does not know what Ic is.
Multimeters usually have fixed Ic to 1mA, but that is usually not accurate enough for comparison between power transistors.
hFE measurement at Ic=100mA is just a fine compromise between accuracy and power dissipation vs. temperature dependency.
At mine proposed NPN/PNP measuring schematic no formula calculations are necessary, mV reading is actually hFE data.
Old 2nd October 2011, 08:57 PM   #1032
Lazy Cat's Avatar
Originally Posted by Smiley 09 View Post
Dear Mr. Andrej
Thank You very much for the most beautiful SSA-V12 version.
You make me the beautiest day since long time awaiting for something to drive my speakers civilized - and You make it.
I know, this is the most Generous Scorpio's gift, You give to the whole worldwide sound-lovers & audio community. Thank You ...
Long Live & let God bless You . .
Andreas
Thank you Andreas
I couldn't even think the SSA Balanced V-12 schematic would make you so happy, I'm really glad it did.
I realize XLR-RCA input connection should also be explained, so here it is.
Old 2nd October 2011, 10:27 PM   #1033
Banned
Originally Posted by Lazy Cat View Post
I saw you have very small Ic in input pair, is that OK, cause usually input transistors should work at 1-5mA collector current. That also means smaller influence of parasitic capacitances if the collector current is larger, which finally brings you wider bandwidth and higher slew-rate, all though I saw yours sim already shows 380V/us.
Thank-you, on that mod, I wanted to propose as less modifications of original values as possible. But you are right, will see if any improvement in increasing the current in the input trans, witch was supposed to be 0.2 ma in the original schematic, very good sounding, in fact. A way too to reduce the values of feedback resistances as you like.;-)
You only can be impressed by yourself, it is just your idea !
I'm more interested to have your opinion and expert suggestions on my differential protection circuit idea.
http://www.diyaudio.com/forums/digit...ml#post2731810
If you like-it, i would be very happy to see-it added to you nice SSAs.
I'm working on an integrated solution: Remote power-on of the amp from the 12v preamp rail, soft power with a current limited delay of 2 sec to take care of the power caps and switch on the Loudspeakers after 4 more seconds or so with this "protect against everything" instant reactive circuit.
I will not leave your thread for no price, i just do not want to bore-you with less noise as possible :-).
As i said, you deserve my sympathy for your passion, generosity and brilliant expertise, makes-me remember when i was young, so many years ago ;-)
Old 2nd October 2011, 11:08 PM   #1034
Yes, this circuit test a transistor at constant collector current level you choose with SW combinations, but the same temperature dependency appears here, base current will go down with temperature rising, so matching is again time dependent. For simplicity and relative only comparisons sake I suggest you to built simpler one.
Thanks LC for your straight forward answer and brilliant advise. Appreciate it.
Old 2nd October 2011, 11:15 PM   #1035
Smiley 09's Avatar
Thumbs up Elegant as always . . .
Thank You Andrej for the elegant I/P solution.
Now It is my turn . . . . . . to put Yours genie design into best possible harmony with my ultra low impedance speakers.
My best regards to You,
Andreas
Old 2nd October 2011, 11:48 PM   #1036
Banned
Some kind of Planar, Orthophase, ot Condenser units ? Ot just paralleled moving coils ones ?
Old 3rd October 2011, 03:01 AM   #1037
Smiley 09's Avatar
Default The most difficult Speakers for all amplifiers on the globe
Esperado,
Apogee Scintilla . . .
Theirs sound is so unique that no conventional speakers come even close.
They require an amp with constant ability drive 0.5 ohm all the time.
Impedance is almost flat line and never leave 0.9 ohm.
The sound, .... incomparable with anything You hear till today - Unique.
They require a nice, civilized arc-welder to drive them, but for return
the listener is constantly in heaven
Andreas
Old 3rd October 2011, 05:40 AM   #1038
What denominations details? R1-R17, C1-C18
Old 3rd October 2011, 05:43 AM   #1039
R1-R18, C1-C18
Old 3rd October 2011, 06:07 AM   #1040
Banned
but for return the listener is constantly in heaven
I believed Hifi was dead ! You use ribbons, i use spherical horns, we gone kick the *** of the smartphone's sound ! Did-you tried some good Class D amp for the basses with your crazy speakers ? They love low impedance. Of course, for treble, SSA would sound gorgeous, i presume.
Ps: my impedance line is quite flat too, between 5.9 and 6.5 ohms all the way, that's one of the secrets ;-)
Symetrical schematics are alike plague in Brazil, do you like them? destroyer X Solid State 151 1st July 2010 02:09 PM
Symetrical out low Zout karsten21 Tubes / Valves 5 1st February 2010 10:19 PM
going balanced/symetrical - what benefits? weissi Solid State 15 20th October 2007 08:06 AM
Symetrical field, is this? Raka Multi-Way 6 14th September 2003 01:21 PM
Non-symetrical SMPS output cm961 Parts 4 21st August 2003 10:27 PM
Copyright 1999-2017 diyAudio
