#991 | |
Thanks LC, awaiting the values necessary to hear an SSA at power .....
#992 | |
Please provide also above mentioned version for me, equipped with the balanced input would be excellent and an option to switch it to a SE input. I have the 1000W-35V AC transformers waiting to be used exactly for the proposed amp. I wonder to use six pairs of the 2STC5949 + 2STA2121 OP transistors. Thank You in advance. |
#993 |
thank you Lazy Cat, yes ill glue the faces together on the input trans and yes a drilled 5mm L bracket for the output fets, thank you so much for the help, steve.
#994 | |
Q1 and Q3 have to be face together, not like it is now, so please rearrange the input section completely. |
#995 | |
20Aac (28Apk) is still way too low a target for driving 1ohm speaker combinations. 50Apk is a more reasonable (minimum) target for driving 1ohm or 2ohms speaker combinations. Last edited by AndrewT; 30th September 2011 at 11:05 AM. |
#996 |
He might want a 200 or 800 watt amp.
Kindest regards Nico |
#997 | |
20 amps capability/ch with full stability, low distortion and good sonics is the goal ... Yes i sometimes exceed 10 amps on dynamic passages, 20 amps output capability per channel should get me there... |
#998 |
20Apk output capability sounds more like a nice target for driving 8ohms speaker loads. Certainly not suitable for driving 1ohm or 2ohm speaker loads.
#999 |
In theory yes , in practical use no. I have never blown an15amp output fuse, 10 amps yes , 15 amps no! 200-400watts rms @1ohm will suffice, plays dynamic enuff with that..
PS: Very few can handle such , even the big ones who claim 50-70 amps capability /ch.. i know , i tried them . |
#1000 |
I accidentally max power tested a power amp with the wrong rail fuses in place.
The load was seeing >400W and yet the tiny test mode fuses in the supply rails did not blow. I don't remember the actual numbers but I posted about 4 or 5years ago. From there I came up with my advice on sizing the rail fuses for all amplifier powers and impedances. Quasi came up with exactly the same method but lowered the fuse rating by a factor of sqrt(2). On that basis the output fuse should be approximately twice the rail fuse ratings since the rail fuses are on 50% duty factor and the output fuse is on 100% duty factor. If you blow a 10A output fuse you have done something really silly. If you blow a 20A output fuse you are worse than silly, you need a "God" looking after you. "God" = or any other supreme being to protect you. |
| Symetrical schematics are alike plague in Brazil, do you like them? | destroyer X | Solid State | 151 | 1st July 2010 02:09 PM |
| Symetrical out low Zout | karsten21 | Tubes / Valves | 5 | 1st February 2010 10:19 PM |
| going balanced/symetrical - what benefits? | weissi | Solid State | 15 | 20th October 2007 08:06 AM |
| Symetrical field, is this? | Raka | Multi-Way | 6 | 14th September 2003 01:21 PM |
| Non-symetrical SMPS output | cm961 | Parts | 4 | 21st August 2003 10:27 PM |
