hi everyone
I want to build Apex amplifier (HV23)(that I founded in page below (thread 44) : MOSFET Amplifier IRFP240/IRFP9240 I found all the parts in this schematic except Q9 (2sc4793) and Q10 (2SA1837) but the salesman suggested me to use 2SC2073 and 2SA940 instead and I'm so confused If anyone could help me I'll be grateful |
#2 |
Pretty much any power transistor should work there, say MJL3281 and MJL1302 should work.
However dont put my word on it, but rather ask Apex himself first.
The point of life is to build atleast one audio amplifier before you die. |
#3 |
he didn't answer my mail
do you know any way I could contact him? |
#4 |
MJE15034/MJE15035. The 2SC2073/2SA940 transistors have too slow fT.
#5 |
thank you jaycee
are you sure about your suggestion? and can I count on it? |
#6 |
Yes! JayCee is a reputable forum member, and the datasheet tells those transistors will do the job just fine.
#7 |
Mouser has this transistors, they cost about 0.5Euro/pcs. The MJE150xx should be good replacement, only the higher internal capacitances can be problem.
Sajti |
#8 |
2sa1837/c4793 are nice driver transistors.
They have reasonable parameters but far from the best available. I would not settle for lesser performance when substituting, when there are many that can at least equal 1837 performance and quite a few that can better them. Try APEX again and be patient.
regards Andrew T. |
#9 |
The 2SC4793 datasheet gives an fT of 70MHz. The one for the MJE15034/MJE15035 quotes an fT of 'only' 30MHz. That might or might not be significant. I don't think so myself.
#10 |
...truth seeker...
There is a source that lists both of them available for $1.29 each.
Electronix Online - Computer and Electronic Parts and Supplies I have bought other items from them that were as promised. I have no experience with the parts you request.
...call me Ed...Special Ed... EnABL kit http://www.diyaudio.com/forums/swap-meet/119852-enabl-kit.html DCB1 parts http://www.diyaudio.com/forums/swap-...ml#post2361098 |
| Spice models for 2SA1837/2SC4793 ??? | Christer | Parts | 3 | 16th May 2010 07:55 PM |
| 2SA1837/2SC4793 Matching Yield? | jkeny | Solid State | 1 | 5th January 2009 01:10 PM |
| Where find 2sc1819 , 2sc4793 , 2sa1837 | r!sc! | Parts | 2 | 27th August 2006 04:17 AM |
| 2sa1837/2sc4793 strange betas | darkfenriz | Parts | 3 | 14th March 2006 07:30 PM |
| TOSHIBA 2SC4793 and 2SA1837 medium power transistor pspice models? | mikek | Solid State | 1 | 24th September 2002 08:14 AM |
| Page generated in 0.10070 seconds (73.59% PHP - 26.41% MySQL) with 10 queries |
