Old 4th August 2011, 07:48 PM   #21
forr is offline forr  France
forr's Avatar
Originally Posted by ingenieus View Post
I assume it is this one:
Comments on Audio Power Amplifier Design Handbook by Douglas Self
Will do so. Thanks.
Yes, it is. There was a thread inviting comments on Samuel's comments. Should desserve much more discussion :
Old 4th August 2011, 07:58 PM   #22
forr's Avatar
I ran the circuit through LTspice and it does look as good as any Blameless. Does the design scale up for higher supply voltages and output power?
Mike made a survey for for the prefered value of amp power, it leads him to adopt 30 W for his project. I think he mentions the possibility of a 100 V DC power supply somewhere. For a very powerful amp, for a sub for instance, he advices using more usual architecture.
Old 5th August 2011, 08:21 PM   #23
Hi Marian
Here's my two pennorth. This amp may seem a little more expensive with 15 transistors but they are all low cost. The small signal ones are BC547/BC557; the protection transistors are current-limiting only (I've not optimised this) and have to carry more current than the small signal so they're BC337/BC327 but could be 547 /557 if you can't get them; the rest are BD139/BD140's and the output 2N3055/MJ2955 pair.
The circuit is essentially a Blameless architecture: differential input, with a decent current source; current mirror which is now standard; a Darlington VAS which has a low emitter resistor (because the VAS current is higher than normal at 25 mA or so); a current source for the VAS; and fully complementary output.
Frequency compensation is my recommended approach: no Miller capacitor, but local "sprog stoppers"; global compensation across the feedback resistor; and an input capacitor to keep the input stage drive impedance low, mainly, for stability.
Simulated distortion is .01% at 60W into 4 ohms and .02% at 20 kHz. It is this performance at high frequencies which demonstrates the better compensation scheme.
Distortion is quite high mainly because of the 4 ohm load. If you run this from 20 to 25V rails at 30W, it will be lower.
The VAS current is high because of the high drive needed by the output transistors. I would recommend the MJ21193/4 but if you can't get those, 2N3055's are OK but need a bit more "push". A compromise would be to use two pairs of 2N3055/MJ2955 in parallel, but that is probably not necessary if you keep the power to 30W.
John
Old 13th January 2013, 02:09 AM   #24
chicks is offline chicks  United States
I'm running mine on the original Dynaco transformer, which results in about 72Vdc after rectification/filtering. I haven't measured, but perhaps 40 WPC?
Old 13th January 2013, 01:26 PM   #25
I like that design and the rationale to its development. More power to you, MJR. It is on the long list of short listed projects!
Now that it's done, chicks, what is your satisfaction from the project - do you like the sound or is it all a bit clean and sharp?
regards
Old 13th January 2013, 02:03 PM   #26
Sounds as good as it looks.
Old 13th January 2013, 06:29 PM   #27
Struth is offline Struth  Canada
Hi Guys
Rod Elliot's circuits were designed many years ago using then-current devices. He has indicated newer devices at the request of his readers. It is the case with most circuits that for each transistor position, many different devices can be subbed in place with little performance difference - at least with Rod's circuits this is the case.
You can sub almost any other part types into his projects. Rod also sells PCBs for most of the amps. If you have Qs about subbing specific parts into any of his circuits he will answer your query.
Have fun
Kevin O'Connor
London Power / Power Press Publishing
www.londonpower.com
Old 13th January 2013, 07:38 PM   #28
Bigun is online now Bigun  Canada
Bigun's Avatar
marian - I give another vote for the DX amplifiers.
All the schematics and details are here: Greg's Web Site
If you want to save money though, and effort, buying a used stereo amp is much easier and quicker route to building one, even with cheap parts.
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 13th January 2013, 09:23 PM   #29
Goodness, I have been a member of this forum for a little bit more than a year, I still learn every time I open a thread, It would be so great getting some of you guy's together deciding on a design, hopefully not more than handful, otherwise we will have a flabbergasted mass of inconsistency ! So many competent people, so many ideas, can we not work and try and design the perfect woman without no VAS, no feedback at all and she is playing a sweet tune. I do enjoy reading these posts, I have build my first lateral mostfet , worked the first time, thank goodness and i do enjoy DIY. Cheers to all you magnificent people !
Cheers from the land of the Springbok !
Jan
Simple low power amplifier morgoth2006 Solid State 1 3rd April 2011 04:02 PM
Low resistance Output control the power amplifier mac1257 Solid State 1 30th March 2011 11:06 AM
DIY Low Power Class A (or AB) amplifier suggestions gareth Solid State 2 16th June 2009 02:46 PM
TDA1514 based amplifier giving low power screamer Chip Amps 11 12th February 2009 04:35 PM
Chassis for low power class A amplifier ppereira Pass Labs 4 16th March 2003 02:52 PM
Copyright ©1999-2013 diyAudio
