Low power amplifier - Page 2 - diyAudio
Old 3rd August 2011, 09:57 AM   #11
Originally Posted by forr View Post
Mike Renardson's amp very detailed project is worth having a look :
MJR7-Mk5 Mosfet Power Amplifier
Methinks that one tries to be just a bit too simple. No differential pair? Less is not always more. In this case it seems like just a whole lot less.
Old 3rd August 2011, 10:20 AM   #12
That amp is superb, me thinks you should research and understand a design before commenting. Did you know that a single cfp input stage is more linear than a LTP ???
Understand that design first, in some iterations that amp far exceeds the performans of so called blameless amps and it sounds excellent too,
Keep reading that site, Mike Renardson is a more than capable designer
Old 3rd August 2011, 10:31 AM   #13
forr is offline forr  France
forr's Avatar
Less is not always more... but may be equal.
At 30 W/ 8 Ohm, the objective performances of this one are on the par with those of the best circuits published all over the world.
Old 3rd August 2011, 10:48 AM   #14
Thanks for the feedback.
I will have another look at the circuit. So there is life outside the Blameless world. Hmmm.....
Old 3rd August 2011, 08:06 PM   #15
forr's Avatar
Renardson's amp is a wonderful illustration of how good a huge amount of global Negative FeedBack with perfect mastering of frequency compensation can do. It totally disqualifies unsupported comments on NFB such as seen today here : Feedback affects Soundstage, Imaging, Transients ?
I already built a MRJ stereo amp using two mono PCBs and currently assembling two MRJ stereo PCBs, all directly furnished by Mike Renardson.
I built my Blameless in 1974, still working. My current interest with amps having a differential input stage now goes to the push-pull VAS structure suggested by Samuel Groner's in figure 56 of his comments on Self's Book.
Old 3rd August 2011, 08:27 PM   #16
Banned
This one is tried and proven by me, its been my primary amp for several weeks, uses all cheap components, MJE340/350 can be replaced with BD139/140 and 2N5401/5551 can be replaced with 2N3904/3906 or BC547/557.
TIP35/36 are about the cheapest transistors you can get in complementary pairs.
Schematic: http://i.imgur.com/EQAzh.jpg
Old 4th August 2011, 09:24 AM   #17
Sounds interesting. Can you tell me a bit more?
Old 4th August 2011, 09:46 AM   #18
Have you read Groner's Thread?
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 4th August 2011, 07:11 PM   #19
I assume it is this one:
Comments on Audio Power Amplifier Design Handbook by Douglas Self
Will do so. Thanks.
Old 4th August 2011, 07:14 PM   #20
I ran the circuit through LTspice and it does look as good as any Blameless. Does the design scale up for higher supply voltages and output power?
Simple low power amplifier morgoth2006 Solid State 1 3rd April 2011 04:02 PM
Low resistance Output control the power amplifier mac1257 Solid State 1 30th March 2011 11:06 AM
DIY Low Power Class A (or AB) amplifier suggestions gareth Solid State 2 16th June 2009 02:46 PM
TDA1514 based amplifier giving low power screamer Chip Amps 11 12th February 2009 04:35 PM
Chassis for low power class A amplifier ppereira Pass Labs 4 16th March 2003 02:52 PM
Copyright 1999-2017 diyAudio
