How to bias Long tail pair....??
Old 2nd August 2011, 11:14 AM   #1
RRITESH is offline RRITESH  India
Send a message via MSN to RRITESH
Default How to bias Long tail pair....??
Hello,
I am trying to make an amplifier ( using transistor) of 5watt ( near by this) for this a long tail pair is required in many circuits...
I have seen many link but i don't understand its biasing.
Please tell how to make it.??
Old 2nd August 2011, 12:07 PM   #2
sregor is offline sregor  United States
Please supply circuit. LTP (long tail pair) operating points are usually determined by current source or resistor to supply rail going to the emitters, then a resistor to ground or to input circuit on one base, and a circuit from feedback to the other base, so that both bases are about the same voltage, and the emitter current is supplied. (I prefer the term operating point rather than bias - YMMV)
Steve
Old 2nd August 2011, 12:10 PM   #3
R.I.P.
Self and Leach both have an understandable explanation of the long tail pair (LTP).
regards Andrew T.
Old 2nd August 2011, 12:14 PM   #4
wahab is offline wahab  Algeria
Originally Posted by RRITESH View Post
Hello,
Transistors
Old 4th August 2011, 03:41 PM   #5
I have seen that links, but what is the use of Long tail (diff. pair) amplifiers and how to bias it??
thanks
Old 4th August 2011, 03:54 PM   #6
Andrew Eckhardt is offline Andrew Eckhardt  United States
What's the use? Matched high impedance +/- inputs. Tons of gain. Some even harmonic suppression. The best way to bias depends on what you expect from the circuit. If you like cheapnis just use resistors.
Old 4th August 2011, 04:18 PM   #7
what about value of resistance??
and if i want to make hi-fi (Good) then??
Old 4th August 2011, 04:41 PM   #8
Find and inspect/analyze the old Accuphase P-300 circuit. Just resistors for current sources can easily be hi-fi. At some point it becomes a matter of taste. You'd have to build or listen to a lot of circuits to really know what you're after. Generally, more transistors is not always the solution.
Far as ballpark figuring out how much collector current you have in an LTP, just figure the emitters are one junction drop beyond the bases, and do V/R on the emitter resistors. Divide the answer in two to find per transistor operating point. To decide how much current you Want requires a lot of mental fiddling with facts about how that changes circuit response alongside the available graphs in the datasheets, or a bunch of messing around in spice. Around 1mA is often pretty close for input stage transistors.
Old 5th August 2011, 04:05 AM   #9
I have seen many pdf of Acc. P-300, but the cicuit where overmy head please give some basic information for designing it and circuit......
I use Lt spice.
thnaks
Old 5th August 2011, 08:31 AM   #10
R.I.P.
Forget LT spice and go and learn how transistor circuits work.
regards Andrew T.
How to bias Long tail pair....??Hide this!Advertise here!
Long-tail pair phase splitter sdinfo Tubes / Valves 14 21st September 2010 12:35 AM
Long Tail Pair Linearizer Electrone Solid State 17 21st April 2009 02:25 PM
Cascoded Long Tail Pair Inferno! panos29 Tubes / Valves 33 15th March 2006 11:26 AM
5687 long tail pair NickC Tubes / Valves 7 14th May 2002 01:04 PM
