Old 2nd August 2011, 08:44 AM   #1
robmil is offline robmil  United Kingdom
Default emitter resistors - how to calculate for discrete opamp.
Hi
I'm looking at building another discrete opamp preamp and while looking at a few designs I have seen quite different emitter resistor values ranging from - 3.9ohms on a bryston design to 33ohms on the JE990 design. Samual Groner
uses anything from 2.7ohms to 18ohms.
Is there a calculation for this resistor, can you scope the difference in values - is there a big difference between say 3ohm, 6ohms and 10ohms in the same circuit? does it make an audible difference going from 30ohms down to a lower value ?
thanks
Rob
Old 2nd August 2011, 11:12 AM   #2
godfrey is offline godfrey  South Africa
Emitter resistors where - input stage or output stage or...?
Either way, yes it makes a difference. Have you got a schematic for reference?
Old 2nd August 2011, 01:35 PM   #3
DF96 is offline DF96  England
Emitter resistors depend on required stage and total open-loop gain, distortion, quiescent current etc. There isn't a quick answer to your question, except to suggest you read a good book on op-amp internal design.
Old 2nd August 2011, 06:16 PM   #4
thanks for the replies
It's the output emitter resistors.
Old 2nd August 2011, 06:21 PM   #5
Output emitter resistors help ensure a clean handover between the two halves of the push-pull. The value depends on the circuit used, and affects the correct quiescent current.
Old 4th August 2011, 02:46 AM   #6
CBS240 is offline CBS240  United States
CBS240's Avatar
Assuming push-pull class AB bias, one place to start might be Zout~= (re+Re)/2.
're' being the intrinsic resistance of the transisor used. There is an audiable effect in that there is an optimum value that results in lower crossover distortion.
All the trouble I've ever been in started out as fun......
Orion emitter resistors ECM Car Audio 5 17th March 2008 01:05 AM
Dual emitter resistors - where from? Stuey Parts 14 10th March 2007 06:58 AM
Why are Emitter-resistors needed? Fritzell Solid State 11 5th February 2007 06:04 PM
Emitter Resistors hawkfeather Solid State 15 29th January 2006 05:28 AM
Emitter Resistors EchoWars Solid State 16 16th July 2005 10:47 PM
Page generated in 0.08690 seconds (75.21% PHP - 24.79% MySQL) with 10 queries
