Help on SoundBoy Amp - Page 3 - diyAudio
Old 27th August 2003, 07:49 AM   #21
Marvellous's Avatar
Default parallel output stage
Wich parallel output is better? A or B?
I think in B R1 will genarate too much heat!
circuit is still underway!
Comments and Ideas Corrections are Still Welcome!
"When a man sits with a pretty girl for an hour, it seems like a minute. But let him sit on a hot stove for a minute—and it’s longer than any hour. That’s relativity." - Albert E
Old 27th August 2003, 08:13 AM   #22
sajti is offline sajti  Hungary
The "B" version is the only good solution.
Sajti
Old 27th August 2003, 08:16 AM   #23
And You can reduce the R1 to 0.1ohm. Due the local feedback inside the CFB the value of this resistor is not really critical.
I found that some small resistors (say 1-2ohms) series with the base of the output trannies help to avoid oscillation.
Sajti
Old 27th August 2003, 11:56 AM   #24
R3 en R12 must be the same value! (the whole schematic)
hugobross how did you calculate the output power?
it's quite easy:
Uv = supply (rail) voltage
Zl = load impedance (4 ohm, 8 ohm, ...)
Prms = continuous power
Prms = (Uv x Uv) / (Zl x 2)
actually Prms will be a little smaller, because there will always be a Uce across the transistors
best regards,
HB.
Old 27th August 2003, 05:47 PM   #25
Marvellous's Avatar
hugobross So you mean they must be both 22K
or must they be both 27K
Old 27th August 2003, 05:57 PM   #26
sss is offline sss  Israel
sss's Avatar
Send a message via ICQ to sss
try also triple putput stage , its the best one but hard to stabilize
Old 27th August 2003, 05:59 PM   #27
with 27k the gain is 27x and with 22K it's 22x, but the most important thing is that both resistors have the same value (otherwise the LTP is not balanced well). gain = R3/R2
You can also place resistors of 47ohm (more or less) in series with the emitters of Q1 and Q2 to reduce small differences between both transistors.
best regards,
HB
Copyright ©1999-2017 diyAudio
