Help on SoundBoy Amp
Old 26th August 2003, 10:59 AM   #11
Marvellous is offline Marvellous  South Africa
Marvellous's Avatar
So if I change BC549, to BD139 and Increase the output resistors to 0.1 The Amp shuold be fine?
"When a man sits with a pretty girl for an hour, it seems like a minute. But let him sit on a hot stove for a minute—and it’s longer than any hour. That’s relativity." - Albert E
Old 26th August 2003, 11:52 AM   #12
sajti is offline sajti  Hungary
Let's discuss about thermal compensation:
1, The thermal resistance of "juction to case", and "case to sink" is no problem in this case. Remember this is problem if Your trannies dissipate power. The bias sensor device doesn't dissipate high power. So the junction will be almost same temperature as the heatsink.
2, With CFB, the thermal runaway caused by the driver but not the output device. This is true, because the feedback loop avoid the change of output device's temperature change.
Sajti
Old 26th August 2003, 11:54 AM   #13
The emitter resistors (R10, R11) is OK with 0R33.
Sajti
Old 26th August 2003, 12:04 PM   #14
Freddie is offline Freddie  Sweden
Default CFP bias
The CFP in the output stage is extremely difficult to handle. Probably you get in trouble with your DC bias
I have an amp with CFP output stage. There's absolutley no problem to get stable bias. No problems at all. I mounted the the Vbe multiplier transistor on top of the driver transistor. Reffering to the schematic above: Q8 mounted on top of Q4. I also used the same sort of transistor for Q8 and Q4.
Old 26th August 2003, 12:32 PM   #15
Marvellous's Avatar
Default Follow Up
So Changes that I must Make are
1. Leave the Emitter resistors (R10, R11) as 0R33.
2. Change BC549, to BD139
3. mount Q8 on top of Q4
What is the maximum Voltage that this Amp can Handle?
Old 26th August 2003, 01:01 PM   #16
Marvellous's Avatar
Default updated Schemetic
Here is the updated Schemetic!
I have started to build my amp will keep you updated
and will post some pics!
Old 26th August 2003, 01:04 PM   #17
Marvellous's Avatar
Please All Coments & suggetions Welcomed!!!
Old 26th August 2003, 01:09 PM   #18
The maximum voltage depended by the transistors You use.
With this devices the maximum voltage about +/-40V, but as I know T3 is the limit for the voltage. Maybe it can be change to MJE340.
But there is another limitation:
Higher voltage means higher output current. And the output device has some limitation to handle the higher current. So over 35V I recommend to use more output devices parallel.
Sajti
Old 26th August 2003, 01:42 PM   #19
Marvellous's Avatar
that makes sense to me!
but now
if I Parallel my outputs then can the output stage handle more voltage or will it be able to handle more current
Old 26th August 2003, 01:52 PM   #20
More current. With TIP31C/32C drivers, and TIP35C/36C output, the output stage can handle +/-50V, and will gives about 200W/4ohms. But with 1pair of output trannies it's not possible.
Sajti
Help on SoundBoy AmpHide this!Advertise here!
