Old 31st July 2011, 09:11 PM   #1
martin5 is offline martin5  United States
Default Quad 303 IEC power socket upgrade
I'm working on my old Quad 303. It deserves a little attention.
One problem is that awkward power connector - mine had a broken pin and soldered power leads. I've made a template for replacing it with an IEC connector. Worked really well.
Here are some pictures.
I've drawn up the panel, if anybody needs the file drop me a note.
Old 1st August 2011, 12:54 AM   #2
Tajzmaj is offline Tajzmaj  Slovenia
Hi
303 is nice vintage amp. I have one.
Bulgin PX0429 3 Pin Male Socket, Quad 303, Racal 1772 | eBay
Quad303 Quad 303 pcb set for renovation/cloning V.4 | eBay
2x BULGIN 3 PIN MAINS CONNECTORS FOR QUAD 33, 303, FM3 | eBay
But of course it will be good ide to replace input connector too......
Best regards, Taj
Old 1st August 2011, 02:39 AM   #3
llwhtt is offline llwhtt  United States
Looks like you could use some new filter capacitors too!
Craig
Old 1st August 2011, 02:05 PM   #4
When I restore mine 303 I find some nice caps from epcos......with bolt on terminals.....
Old 2nd August 2011, 10:31 AM   #5
robmil is offline robmil  United Kingdom
Those filter caps have had it Better change them REALLY soon (like yesterday) as they are leaking electrolyte.
rob
Old 2nd August 2011, 02:08 PM   #6
At the moment I'm on vacation but can check which caps I used.....but I buy everything from farnell......
Best regards, Taj
Old 18th September 2011, 06:17 AM   #7
ms08 is offline ms08  United Kingdom
I have three 303's two have recently bee re-built to varying degrees using DADA supplies.
Old 24th September 2011, 08:16 PM   #8
I've bult several 303 clones but with some mods. The best was to use new epi 3055's and most of the HF roll-off capacitors could be halved. Performance improved from the standard 35 kHz with original capacitor values and RCA original transistors to over 70kHz, using ST 3055's (but I suspect ON semi would be similar) and (at least I thought so) sounded better for it.
John
Old 23rd January 2012, 12:06 AM   #9
alfian is offline alfian  Serbia
I did a true esoteric renewal of 303, upgrading all except the original casing and transformer. Epcos, Elna, Wima, RIFA & SMica Caps, Bourns trim, Kiwame, Mills & Takman resistors, ON Semi 15030/31 + 15003/4, J507/510, Van Den Hul cs18/16 wiring... But, the new metric screws are not matching to the old ones!!!
Does anyone know where I can find new screws for 303 (4BA thread)?
Branko, Serbia
Quad 303 : Upgrade output stage to be fully complementary askbojesen Solid State 32 18th February 2012 05:12 PM
WTB: AC Power socket (IEC receptacle) vrao81 Swap Meet 3 30th September 2008 10:26 PM
Should I keep these capacitors on my IEC socket? bikehorn Power Supplies 5 2nd August 2007 04:54 PM
Upgrade advice - general and specific (Quad 33/303) trydecaf Solid State 0 8th February 2005 11:04 PM
Page generated in 0.10848 seconds (72.22% PHP - 27.78% MySQL) with 11 queries
