So I'm a big dummy, I was replacing bulbs while the unit was on, so I could see which ones were bad. Aaaaaaaaand I was using metal tweezers. Guess who shorted it to ground? Yup. I'm a genius.
At any rate, teh display instantly went dark, but I can't find a blown fuse anywhere. There a bunch of fuses inside, but each one tests good. Any ideas? Thanks! Charles. |
#2 |
If everything else works then pick a bulb and trace back taking voltage readings from each bulb end to its final destination on the PCB.
Could be there is a bulb driver transistor, particularly if the display is dimmable etc or goes out in standby. QX40000... whats that ?
------------------------------------------------------- A simulation free zone. Design it, build it, test it. |
#3 |
Is this a QX-4000, the Quadraphonic receiver from the mid 70's?
If so look for the 3 amp fuse that feeds the lights. It should be labled "F2". I think you have to take the bottom off to get to it. Last edited by Ronode; 31st July 2011 at 11:17 AM. |
#4 |
I was half asleep when I posted my first reply.
Didn't see you had checked the fuses. If you measured the light circuit fuse while still in the holder your ohmmeter would see the transformer winding thru the light bulbs and show continuity even though the fuse is blown. Did you pull the fuse to test it? |
#5 |
That was it, fuse was blown but I was reading through the transformer winding. Going to replace it with a fuse holder, those glass fuses are a bitch to solder to directly. I've got it back up and running now, thanks!
Charles. |
#6 |
i dare to presume that you did other service things in the amplifier also .... if not you will have to sooner or later ...
SERVICE ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr |
#7 |
I deoxited all the pots and switches, and it plays again... but the right channel is louder than the left, and in a bass-heavy, breaks-up-at-louder-volumes kind of way. (ie, the left channel sounds correct, the right channel shouldn't be this way). Not the speakers. Not sure what's wrong exactly, but I was going to start by re-capping the main amplifier boards and head amp boards.
Charles. |
#8 |
Note, it's only the front right channel that's behaving in this manner. If I switch to 4-channel mode the rear channels are the same volume and bass levels, and sound perfect. So I'm guessing the problem is in the amplifier board for the front channels.
Charles. |
| Misc. ST-bulb (coke-bottle shape) tubes (and two GT-bulb) FS | GordonW | Swap Meet | 0 | 4th January 2008 03:14 PM |
| Page generated in 0.09346 seconds (77.76% PHP - 22.24% MySQL) with 10 queries |
