Old 31st July 2011, 03:54 AM   #1
thanong is offline thanong  United States
Default Need help for Musical Fidelity B-1 Integrated Amp
Hi all,I'm very need your help.I got Musical Fidelity B-1 Integrated Amplifier with three prong plug Australia style.This amp can wiring between 240 v and 120 volt.I don't have step up transformer and I don't have circuit to wiring power transformer to 120 v.Anyone can help please.
Old 31st July 2011, 10:32 AM   #2
Mooly's Avatar
So you have a 240 volt amplifier that you want to run on 120 volts ?
It might help if you posted some detailed pictures of the transformer and its wiring.
Normally its a case of connecting either the appropriate tapping on the primary or perhaps taking two series connected windings and connecting them in parallel but you need to be sure before you do that.
A simulation free zone. Design it, build it, test it.
Old 31st July 2011, 05:42 PM   #3
Thanks for your help Mooly, yes now its tapping in 240 volt but its can tapping to 120 volt to this is the multi volt transfomer.The primary has orange and black color wire wiring to power switch purple and white color wire are soldering together.Pink and brown wire are left free .I don't have camera to take a picture to show everyone.If someone have the circuit or have the B-1 USA version could tell the detail better than me.Thanks again Mooly.
Old 1st August 2011, 01:03 AM   #4
unclejed613's Avatar
disconnect the purple/white. connect purple to the black and connect white to orange. white and black are one winding, and orange and purple are the other winding. you know the phase relationship between the two windings because of the way they are connected now. the other open wires are 100V taps, so leave them open.
Vintage Audio and Pro-Audio repair ampz(removethis)@sohonet.net
spammer trap: http://www1284177414881.v-dc.net/
Old 2nd August 2011, 03:04 PM   #5
Thanks a lot unclejed613 for detail.I will try this weekend and will tell you later.Appriciate.
Old 4th August 2011, 02:59 AM   #6
I reconnect as you advice.It's work now.Secondary tap 28-0-28 volt and dc 35 volt after rectifier.I played vinyl,cd,tuner for testing around 1 hrs it work fine and sound nice .But I wonder left channel 2 pair of 2n3055 power transistor ( parallel quasi-compimentary ) run hotter than right channel.I measure everything are normal.It doesn't have thermal compensator I fear it will fail later.How to measure and adjust idle current ? Thanks a lot unclejed613.
Old 5th August 2011, 04:27 AM   #7
It work now.I measure between both emitter resistor and turn down VR-2 until multimeter show 20 millivolt power transistor run just warm and adjust VR-3 for DC of-set around 10 millivolt.I'm not sure it's correct or not,but $12.99 little amp from goodwill sound good enough for my ear.Thank you very very much unclejed613.
Musical Fidelity A1 Integrated repair/upgrages Rubin Solid State 14 11th February 2012 06:24 PM
MUSICAL FIDELITY XRAY & XDAC batteryman Digital Source 7 10th July 2011 04:58 PM
musical fidelity p 150 power amp bdm47 Solid State 0 22nd March 2011 06:29 PM
pre-amp out - musical fidelity puginfo Solid State 3 1st January 2008 10:35 AM
Musical Fidelity A3 integrated, loose vol knob ninety Solid State 4 15th September 2007 04:05 AM
Page generated in 0.10255 seconds (78.39% PHP - 21.61% MySQL) with 10 queries
