#981 |
No.
4700uF +4700uF connected in series = 2350uF 60Vdc is very close to the 63V maximum rating for the majority of affordable smoothing caps. You may find that in worst case conditions that your mains supply takes your smoothing caps above 63Vdc. That will require you to specify 75V or 80V capacitors. |
#982 |
Can someone tell me how a speaker protection module works?
Works a speaker protection module only if the module gets voltage from the amplifier? I hear no click after 10 seconds as it is connected, see picture 2 The small transformer is 1 x 12 volt. Regards, Rudy
It’s not what you know, but who you know “and where they are” Last edited by BMW850; 18th February 2012 at 01:38 PM. |
#983 |
Another photo, this is the good way how the amplifier is connected to the module?
Regards, Rudy
It’s not what you know, but who you know “and where they are” Last edited by BMW850; 18th February 2012 at 02:17 PM. |
#984 | |
According to the circuit diagram found here, that module connects between the amplifier output and the loudspeaker. When powered by a 12Vac supply, if a DC offset of positive or negative polarity is detected at the amplifier output, the relay contacts open and disconnect the load. There is also a delay of a few seconds before the relays close at power-up. Regards, currentflow |
#985 |
I hear no click after 10 seconds as it is connected. Regards, Rudy
It’s not what you know, but who you know “and where they are” |
#986 | |
There has to be no voltage from the amplifier for the relays to connect the output to the speakers. Last edited by currentflow; 18th February 2012 at 02:31 PM. |
#987 |
Kevin emailed me this:
Dear Sir: http://www.okaphone.nl/product/images/212048c.jpg This transformer is 12-0-12 full wave output. What you need should be simpler one. Just need to have one 12-0 output, 1A current is quite enough. Sincerely, Kevin - vintage_audio_lab Oke currentflow, I wire one to the 0 and the other to the AC. Thanks
It’s not what you know, but who you know “and where they are” Last edited by BMW850; 18th February 2012 at 02:40 PM. |
#988 | |
#989 |
I measuring 13,2v between 0 and the entrance of the 7812 the current is to low.
I have the speaker protection tested with the light bulb tester and speaker protection works well. The speaker protection click after 6 seconds Rudy
It’s not what you know, but who you know “and where they are” Last edited by BMW850; 18th February 2012 at 03:36 PM. |
#990 | |
I don't think your transformer is adequate. What is its specification? Can you measure the output from the regulator: a) with the relays on, and b) with the relays off please. |
| Dx Blame ST - Builder's thread - post pictures, reviews and comments here please. | destroyer X | Solid State | 1663 | 14th February 2013 04:38 AM |
| Dx Blame MKIII Supercharged will soon be released | destroyer X | Solid State | 341 | 7th December 2012 04:50 AM |
| group buy for DX Blame MKIII Hx PCBs | ByronInLawrence | Group Buys | 247 | 5th December 2012 12:05 AM |
| Group By: DX Blame MKIII Hx boards | ByronInLawrence | Group Buys | 9 | 19th July 2011 07:21 AM |
| Dx Blame MKII, an obvious evolution from the Dx Blame ES/ST | destroyer X | Solid State | 4 | 25th September 2010 06:41 PM |
