Dx Blame MKIII-Hx  - Builder's thread
Closed Thread
Old 9th February 2012, 04:20 PM   #971
evette is offline evette  Canada
Send a message via Yahoo to evette
4,7 ohms evette
Old 10th February 2012, 02:24 AM   #972
harmonicconverger is offline harmonicconverger  Philippines
Can i use 2sc2581 as a substitute for power transistor?
Old 10th February 2012, 08:31 PM   #973
a.wayne is offline a.wayne  United States
Sin Bin
Can we confirm R24 is 2.2 ohm ....?
Old 10th February 2012, 10:06 PM   #974
BMW850 is offline BMW850  Netherlands
BMW850's Avatar
The Dx Blame MKIII-Hx boards you can order on Ebay, Destroyer DX Blame MK III PCB authorized version!!
http://www.ebay.com/itm/Destroyer-DX-Blame-MK-III-PCB-authorized-version-/320794512395?pt=LH_DefaultDomain_0&hash=item4ab0d7 cc0b
Rudy
It’s not what you know, but who you know “and where they are”
Old 11th February 2012, 02:19 PM   #975
BMW850's Avatar
I've changed 390R resistance to a 2.2 K resistor.
Now regulates my Fettle Preamp better, it was 4 steps on listening quality with the 41-step series attenuator of Acoustic Dimension.
Now it take 10 steps, much nicer listening with the with the 41-step series attenuator.
Have now ordered 2 pieces Charcroft Z-Foil Resistors 2K2 0.4 W.
For replacement of the 2.2 K TAKMAN Audio Metal Film Resistors.
Wonder what the differences will be.
I have told you all before:
Also I have the bridged with a wire (Silver/Gold) the 1uF capacitor and this sounds much better, sounding instruments now much looser/opener.
I will replace these 1 uF (MKT1813 1, 0uF Roederstein 100V) one more time and replaced by a 1uF Mundorf silver/gold/oil I still have lying around here.
I hereby wish like some help and suggestions from fellow forum members what a good capacitor is for this place in the signal path.
The rule is NO capacitor "sounds better" than a capacitor.
I ask this because I want to listen one more time to the passive Inductive Volume Control of TRIBUTE Audio again with “the best cap” on this place.
NOTE:
The bridged wire (Silver/Gold) with the 1uF, can only if you used a preamplifier and no passive volume control.
Then you have the chance you'll hear steps of the passive volume control.
Then you hear a bit of DC voltage with your passive volume control.
Most Preamps (99%) have an output capacitor that the DC stop.
You will be thinking how these Dx Blame MKIII-Hx sounds?
I do first some modifications to this amplifier, changed with some salt and pepper but I can say this amplifier sound good ...
Rudy
Old 12th February 2012, 10:14 PM   #976
BMW850's Avatar
I have the 1 uF mundorf s/g/oil tested with preamp but this was also no success no cap sounds better.
Rudy
Old 14th February 2012, 02:42 AM   #977
space2000 is offline space2000  Singapore
I have 40 pcs of E cap 4700uf 35v seating at home. how can i use it with this amp? my dc power supply is 60V -0 - 60V
Michael
Old 14th February 2012, 04:43 AM   #978
meanman1964 is offline meanman1964  Belgium
meanman1964's Avatar
selling,you can't use them for this amp.
Old 14th February 2012, 05:17 AM   #979
alex mm is offline alex mm  Romania
alex mm's Avatar
You can use adding two supply like in attachment
Old 14th February 2012, 09:53 AM   #980
That means i can use two caps in series on each rail to increse the voltage. if i use this two caps in series my cap value still count 4700uf or 4700uf X2 = 9400uf?
Thank you
Michael
Closed Thread
Dx Blame MKIII-Hx  - Builder's threadHide this!Advertise here!
Dx Blame ST - Builder's thread - post pictures, reviews and comments here please. destroyer X Solid State 1874 28th August 2017 09:53 PM
group buy for DX Blame MKIII Hx PCBs ByronInPortland Group Buys 252 13th May 2016 04:14 AM
Dx Blame MKIII Supercharged will soon be released destroyer X Solid State 346 22nd April 2014 03:01 PM
Group By: DX Blame MKIII Hx boards ByronInPortland Group Buys 9 19th July 2011 07:21 AM
Dx Blame MKII, an obvious evolution from the Dx Blame ES/ST destroyer X Solid State 4 25th September 2010 06:41 PM
