Dx Blame MKIII-Hx  - Builder's thread
Closed Thread
Old 4th February 2012, 02:48 PM   #941
a.wayne is offline a.wayne  United States
Sin Bin
Yes you can just not WMG music without permission .....
Old 4th February 2012, 05:28 PM   #942
Junie is offline Junie  Philippines
Nice one Rudy, great set-up.
Old 4th February 2012, 07:57 PM   #943
BMW850 is offline BMW850  Netherlands
BMW850's Avatar
Thanks Junie,
Is there someone who has already tried without the 1uF cap ?
If you're a preamplifier used with this 1uF cap is the emotion of the sound completely gone.
Therefore, said Carlos first try without preamp and and use an passive volume control, he was quite right.
My passive volume control (41-step series attenuator from Acoustic Dimension) sounds better than my active Fettle preamp, with the 1uF cap. (
Can you still follow?)
BUT only without this 1uF cap my active Fettle preamp sounds better with the 41-step series attenuator from Acoustic Dimension.
Today I also listened music with an passive Inductive Volume Control from TRIBUTE and these one is the best from all "in my set".
And if you you use passive volume control, you take a very good 1uF cap because this cap sits in the signal path.
Rudy
Itís not what you know, but who you know ďand where they areĒ
Old 4th February 2012, 08:53 PM   #944
lanchile is offline lanchile  United States
lanchile's Avatar
Originally Posted by BMW850 View Post
Thanks Junie,
Rudy
it is a good thing to use input caps just in case of a gear connected to the inputs carries some dc...try to use a better quality cap. I use a passive volume too and I have Sonicap 4.7uf that are doing a wonderful job. There are better and more expensive caps ,but that does not mean they will sound better.different caps...different sound. Good luck with your hunting!
Old 5th February 2012, 07:25 AM   #945
harmonicconverger is offline harmonicconverger  Philippines
i have 29-0-29 volts transformer. i'm from philippines. our voltage from outlet is 220v, but i have this large transformer with 100v labeled in the primary. can i use 110 to 220v converter?
Old 5th February 2012, 09:26 AM   #946
one more question. i have this another transformer with black, green, yellow, white and red color leads. can you tell me what this color codes stand for?
Old 5th February 2012, 10:31 AM   #947
space2000 is offline space2000  Singapore
Today i had changed all transistors with new including power transistors.
it still producing weak and distorted sound. high freq distorted too.
is this crossover distortion?
Michael
Old 5th February 2012, 10:40 AM   #948
currentflow is offline currentflow  United Kingdom
Michael
It's now likely that you have a board problem in the form of open or shorted tracks or an incorrect component fitted somewhere. Are you able to post a detailed picture of your board and its power wiring & grounding?
Is the lower end of R5 properly connected to ground?
currentflow
Old 5th February 2012, 11:02 AM   #949
R.I.P.
you cannot easily convert a 100Vac transformer to run from 220Vac mains supply.
You can buy a 220Vac to 100Vac transformer that will feed the correct voltage to the 100Vac transformer.
Buy the correct transformer for your 220Vac mains supply.
regards Andrew T.
Old 5th February 2012, 11:04 AM   #950
R.I.P.
show us some or a lot of details. Pics of the transformer. pics of the labelling, pics showing the diameter of the coloured leads copper cores.
regards Andrew T.
Closed Thread
Dx Blame MKIII-Hx  - Builder's threadHide this!Advertise here!
Dx Blame ST - Builder's thread - post pictures, reviews and comments here please. destroyer X Solid State 1874 28th August 2017 09:53 PM
group buy for DX Blame MKIII Hx PCBs ByronInPortland Group Buys 252 13th May 2016 04:14 AM
Dx Blame MKIII Supercharged will soon be released destroyer X Solid State 346 22nd April 2014 03:01 PM
Group By: DX Blame MKIII Hx boards ByronInPortland Group Buys 9 19th July 2011 07:21 AM
Dx Blame MKII, an obvious evolution from the Dx Blame ES/ST destroyer X Solid State 4 25th September 2010 06:41 PM
