Old 3rd February 2012, 02:57 PM   #931
Originally Posted by space2000 View Post
I am listening from 8ohms loudspeaker, No other then this.
That speaker load should be fine. Is the speaker possibly damaged? (sorry to ask!) Are the transistors you've fitted exactly those as specified? If not, do the ones fitted have the same pinouts?
Try using a different pair of output transistors after disconnecting the originals, then re-adjust the bias setting.
The lower end of R5 isn't open-circuit to ground by any chance?
As BMW850 suggests, you may have one or more fake transistors...
currentflow
Old 3rd February 2012, 03:12 PM   #932
BMW850 is offline BMW850  Netherlands
BMW850's Avatar
I'm listening now without the 1uF capacitor in the signal path, I short-circuit this cap with a wire.
Much more depth in the sound
Rudy
It’s not what you know, but who you know “and where they are”
Old 3rd February 2012, 05:08 PM   #933
where is the 1uF?
What does it replace?
Where is the short circuit?
What is more depth?
regards Andrew T.
Old 3rd February 2012, 05:52 PM   #934
a.wayne is offline a.wayne  United States
a.wayne's Avatar
It's the input coupling cap Andrew .....
Old 3rd February 2012, 10:39 PM   #935
Thanks. I will check my speaker and the transistors again. it could be cause by fake or weak transistor at output. I don't like MJE. Can i change some transistors?
T8=2sc4793
T9=2sa1837
T10=2sc4793
T11=2sa1837
All these parts are easy to get here.
Michael
Old 4th February 2012, 01:26 AM   #936
My speaker has no problem.
I must note that I am using output Power transistor 2SC5200 and 2SA1943. It can be use in this amp as noted ealier in this forum.
Michael
Old 4th February 2012, 09:03 AM   #937
Michael
Your transistor substitutes as listed should work fine. Other areas to investigate include PCB track breaks and/or shorts and faulty components. Do you have an oscilloscope?
currentflow
Old 4th February 2012, 12:43 PM   #938
BMW850's Avatar
Have a video made of the amplifier with my mobile phone.
Hopefully I have the music not too loud, no talking about distortion sounds
Here you can also see my acoustics ceiling treatment.
You also see my jumper/wire over the 1uF, it sound much better without the 1uF.
Special Note about the 1uF cap, you can do this only if you use a preamplifier, NOT with a passive volume control.
I'm not going in discussion why not, some things come not from myself.
You have chance you get than a problem, because you are going to hear the steps of the passive volume control.
You also select a piece of DC along with your passive volume control
My Fettle Preamp (and 99% of other preamps) has a output capacitor, which stops the DC, and also before the pre.
Video now uploading (748mb):
http://www.youtube.com/watch?v=X0pkmtH0058
Rudy
Old 4th February 2012, 01:18 PM   #939
a.wayne's Avatar
Video blocked ...............
Old 4th February 2012, 02:33 PM   #940
BMW850's Avatar
Video may contain content that is in possession of or administered by these entities:
• Entity: WMG and UMG content type: audio recording.
Therefore, your video is blocked in the following locations:
American Samoa, Guam, Northern Mariana Islands, Puerto Rico, United States, United States Minor Outlying Islands, United States Virgin Islands.
Nowadays one can download music anywhere in the highest bitrate and a simple video is blocked by youtube
Dx Blame ST - Builder's thread - post pictures, reviews and comments here please. destroyer X Solid State 1571 Yesterday 09:50 PM
group buy for DX Blame MKIII Hx PCBs ByronInLawrence Group Buys 246 18th February 2012 08:33 AM
Dx Blame MKIII Supercharged will soon be released destroyer X Solid State 335 20th November 2011 03:37 AM
Group By: DX Blame MKIII Hx boards ByronInLawrence Group Buys 9 19th July 2011 07:21 AM
Dx Blame MKII, an obvious evolution from the Dx Blame ES/ST destroyer X Solid State 4 25th September 2010 06:41 PM
Page generated in 0.12345 seconds (76.28% PHP - 23.72% MySQL) with 11 queries
