Dx Blame MKIII-Hx - Builder's thread - Page 92 - diyAudio
Old 28th January 2012, 10:33 PM   #911
ByronInPortland's Avatar
Just my 2 cents:
I've been listening to my DX Blame for a while now. I'm very impressed with the sound. It is very detailed and no audible noise. I wish I had the knowledge & equipment to measure things like distortion & noise and max power before clipping. I'll just have to be content knowing that I love the sound.
I, too, have decided to buy a speaker protection circuit. I get a pretty big thump at turn-on, and a loud "ZIP" noise after turn-off when the PS caps finally discharge. I'm going with Elliott Sound Products again. I've built a few of his kits and have become loyal customer.
I meant to post a final parts list for my build, but I replaced many parts, and had other projects going on at the same time. I can't figure out, from the invoices, which parts ended up in the final version! And it's just too much work to take it apart to inspect the boards again.
I'm going to unsubscribe from this thread, as I'm off to other projects. Feel free to send a PM if anyone has any questions for me.
-Byron
Old 28th January 2012, 10:48 PM   #912
a.wayne is offline a.wayne  United States
Sin Bin
^^^ Post is useless without pics ...... ..
Old 29th January 2012, 12:41 AM   #913
Send a message via MSN to smartx21 Send a message via Skype™ to smartx21
Originally Posted by astankov View Post
I think Carlos leaved the forum forever...
Read this post: http://www.diyaudio.com/forums/solid...ml#post2856519
Max.
Old 29th January 2012, 12:44 AM   #914
Originally Posted by a.wayne View Post
What about Brazilian forum ?
He has been banished a couple of times from brazilian most known forum (htforum). Maybe you can find him at DIYSMPS.COM.
Max.
Old 1st February 2012, 12:48 PM   #915
I need help. I am not good in electronics. its got some problem, it sounding very week distorted. output showing 256ml volts. I am using one pare of output power trantistor to check if its work. How to solve this problem?
This is the circuit diagram
http://www.diyaudio.com/forums/attac...-28th-2011.pdf
Thank you
Michael
Old 1st February 2012, 02:43 PM   #916
meanman1964's Avatar
Please give some information like voltage rail,bias etc.
I hope you don't use +- 64 VDC for one pair of trannies
Old 1st February 2012, 08:35 PM   #917
I just keep bias pot at 50% not yet measure, don't know how to measure. Rail voltage 60VDC but i do have 25VDC transformer too. how to measure bias? Thanks.
Old 1st February 2012, 10:54 PM   #918
Try with that 25 Volts transformer.How many VA is the transformer?
About the bias read back a few posts
Old 2nd February 2012, 04:26 AM   #919
I just adjusted the bias. Now showing the voltage at Resister R29 470 oh one side to another side 3ml volt. still having same problem. Zobel properly connected.
I used 25vdc.
My transformer 25v 5amp and another is 60VDC 10amp.
Old 2nd February 2012, 09:25 AM   #920
I used 25vdc.
Hi space2000,
As I understand it, you are using a 25-0-25V supply. Did you install 100 ohm resistors in place of both supply fuses before making this measurement?
According to the circuit you provided, you need to measure the voltage across R39 not R29. R39 is 470 milliohms (0.47 ohms). Maybe it was just a typo . You should find a similar voltage exists across R44.
If in doubt, you could follow the procedure in post #200 of this thread to set up the bias, before further diagnosis.
currentflow
Dx Blame ST - Builder's thread - post pictures, reviews and comments here please. destroyer X Solid State 1810 27th July 2016 05:34 PM
group buy for DX Blame MKIII Hx PCBs ByronInPortland Group Buys 252 13th May 2016 04:14 AM
Dx Blame MKIII Supercharged will soon be released destroyer X Solid State 346 22nd April 2014 03:01 PM
Group By: DX Blame MKIII Hx boards ByronInPortland Group Buys 9 19th July 2011 07:21 AM
Dx Blame MKII, an obvious evolution from the Dx Blame ES/ST destroyer X Solid State 4 25th September 2010 06:41 PM
Copyright 1999-2017 diyAudio
