Dx Blame MKIII-Hx  - Builder's thread
Closed Thread
Old 13th September 2011, 08:51 AM   #81
R.I.P.
Suppressors for switch noise are available.
I wonder if those are what you refer to?
regards Andrew T.
Old 13th September 2011, 09:42 AM   #82
mj777 is offline mj777  Australia
Default heat sink
Originally Posted by ByronInLawrence View Post
I already asked this question, but I'll try one more time.
I like the profile for the heatsinks for the MJE15030 and MJE15033 transistors Alex drew in the silkscreen, but can't find them. Does anyone know of such heatsink? If not, what is everyone using?
-Byron
Please check this link maybe it will help,TO-220 Heatsinks, and there price are not that expensive, I have ordered online from them many times and the quality of the parts are also good.
regards,
mj777
Old 13th September 2011, 10:17 AM   #83
alex mm is offline alex mm  Romania
alex mm's Avatar
........yes this heatsink it's like in the pictures from above link
Alex.
Old 13th September 2011, 06:35 PM   #84
ByronInPortland is offline ByronInPortland  United States
ByronInPortland's Avatar
Thumbs up I found the perfect one
Thanks, everyone for the links. I found one exactly like what Alex drew on the silkscreen. It is at:
Heatsinks - TO-220 - TO220ST
Old 13th September 2011, 11:14 PM   #85
The descriptions just said they're good for noise suppression. They didn't say what kind of noise. Here are several examples.
http://www.okaya.com/images/noise/1100.pdf
Vishay - Vishay's New X2 Interference Suppression Film Capacitors Feature Capacitance Values from 0.001 μF to 4.7 μF and Pitch Sizes Down to 7.5 mm
http://www.kemet.com/kemet/web/homepage/kechome.nsf/vapubfiles/KEM_F3011_PME271M_X2_275.pdf/$file/KEM_F3011_PME271M_X2_275.pdf
http://www.cde.com/catalogs/MPX.pdf
I found that they all had leads which were too far apart, so I went with normal caps.
Old 14th September 2011, 11:33 AM   #86
destroyer X is offline destroyer X  Brazil
destroyer X's Avatar
Default I will disassemble my prototype to save parts
Was tested and worked great..no reason to keep prototype assembled when i need some parts are there not in use.
MKIII Hx prototype will be dismantled to save usefull parts - YouTube
regards,
Carlos
Restriction removed ; ttps://www.youtube.com/watch?v=3ioyOjAzDt0; https://www.youtube.com/watch?v=uFcnddpe3MU
Old 14th September 2011, 05:26 PM   #87
meanman1964 is offline meanman1964  Belgium
meanman1964's Avatar
Here you've a regulator
Old 14th September 2011, 07:21 PM   #88
a.wayne is offline a.wayne  United States
Sin Bin
Meanman ,
What is that regulated PSU good for, VAS ? or for the main amp as well ?
Old 14th September 2011, 08:37 PM   #89
Main power
Old 14th September 2011, 10:21 PM   #90
Default There's a trimpot A. Wayne, so you can adjust
You can have 85 volts entering and adjust to any voltage you need...this gonna be a laboratory power supply, to feed several different power amplifiers as we can adjust output voltage.
The circuit shown, with Apex name on it, is the same i use that was a copy from Ampex Open Reel Video Tape recorders down the seventies..also used by Sony.... it is a generic series pass circuit that works very well...performance of this circuit is great and regulation can be within 5 percent.
Depending how many power transistors you have in the series pass, you can use it as main power supply and can use it as secondary power supply feeding VAS and first stage...in this last case you will not need a powerfull transformer and will not need high power series pass transistors.
Adjustable stabilized power supplies can be good as step down regulators, so you can have a 85 volts transformer and will need to power a 65 volts amplifier...then it will be a helping hand.
The trouble is that they must be as fast as your amplifier and better when the supply is faster than your power amplifier, say, correcting errors (voltage variations) very fast.
The main need, in my point of view is to use at least 20 plus 20 thousand microfarads in the output of the series pass, and hard is to do this way and continue to have a fast response of your error amplifier (that transistor and zener in the feedback patch)
A good circuit can help a lot your performance, will reduce modulations, will reduce distortions, will increase peak power compared with a non regulated supply (as voltage will stand still in the preset value)....but can destroy your amplifier performance if bad designed, bad adjusted, bad tuned to your specific current demand.
regards,
Carlos
Closed Thread
Dx Blame MKIII-Hx  - Builder's threadHide this!Advertise here!
Dx Blame ST - Builder's thread - post pictures, reviews and comments here please. destroyer X Solid State 1874 28th August 2017 09:53 PM
group buy for DX Blame MKIII Hx PCBs ByronInPortland Group Buys 252 13th May 2016 04:14 AM
Dx Blame MKIII Supercharged will soon be released destroyer X Solid State 346 22nd April 2014 03:01 PM
Group By: DX Blame MKIII Hx boards ByronInPortland Group Buys 9 19th July 2011 07:21 AM
Dx Blame MKII, an obvious evolution from the Dx Blame ES/ST destroyer X Solid State 4 25th September 2010 06:41 PM
