Dx Blame MKIII-Hx  - Builder's thread
Old 18th January 2012, 06:24 PM   #791
Rudi_Ratlos is offline Rudi_Ratlos  Germany
Rudi_Ratlos's Avatar
Rudy, the voltage you are measuring across the "fuse-resistor" depends on the value of this resistor.
As I understand it, Carlos recommends a quisecent current of 100mA.
If you use a 47 Ohm, then your multimeter will read 4.7V; if you use a 100 Ohm resistor, your multimeter will read 10V.
Please check Carlos' recommendation once more.
Best regards - Rudi
Old 18th January 2012, 07:40 PM   #792
BMW850 is offline BMW850  Netherlands
BMW850's Avatar
I short the input signal hot to signal ground.
Everyting is good, emitter resistor I measure 1 milivolt constant.
@ Rudi, I measure over 100 ohm resistor 4,7 volt.
And I check Carlos recommendation
Rudy
Itís not what you know, but who you know ďand where they areĒ
Old 18th January 2012, 07:55 PM   #793
What is the output offset in mVdc?
What is the output noise in mVac?
regards Andrew T.
Old 18th January 2012, 08:30 PM   #794
BMW850's Avatar
I short the input signal hot to signal ground, and I measure 19,20 volt DC output offset at the speaker terminals.
Sorry you or anybody else explain to me how I measure that?
I short the input signal hot to signal ground, I measure between 1,5 and 3,2 mV AC output at the speaker terminals, it goes up and down.
Rudy
Old 18th January 2012, 09:15 PM   #795
BMW850's Avatar
I forgot to mention. I power up directly from the mains, and I have the fuse in there.
Tomorrow evening I go further, go to sleep now early day tomorrow.
Let me know where are the errors
Rudy
Old 19th January 2012, 10:00 AM   #796
Originally Posted by BMW850 View Post
I short the input signal hot to signal ground, and I measure 19,20 volt DC output offset at the speaker terminals..............
You are being foolhardy.
Why are you powering up direct on line?
The 19Vdc output offset shows there is a wiring error.
The variable 1.5mVac to 3.2mVac could be showing noise or oscillation or hum at the output. But you must sort the output offset first and any oscillation if it exists, before you can be sure that the mVac reading is noise.
regards Andrew T.
Old 19th January 2012, 12:42 PM   #797
BMW850's Avatar
I have all mounted components as described on print screen, hopefully there are no errors on print screen.
All parts measured and sorted before and when I took in the components for soldering, again as first measure the resistors.
Well that I have been reckless, the output offset mVdc and the output noise in mVac I forgot to measure that yes that was stupid, all the other measures good
The GND I use as the minus for the speaker output (out the +) and the other 3 wires (+60v -60v GND) are good connected otherwise we have a lot of smoke.
I know it’s difficult to tell what’s wrong from a distance, but where shall I search the error first.
Rudy
Old 19th January 2012, 01:04 PM   #798
Rudy,
do all legs of all transistors that you have mounted vertically, show infinite resistance (MOhm scale on your DMM) in respect to the heatsink?
Rudi
Old 19th January 2012, 01:08 PM   #799
Pics of the open chassis and close ups of the detailed wiring.
regards Andrew T.
Old 19th January 2012, 01:29 PM   #800
BMW850's Avatar
Full resolutie is to big
Dx Blame MKIII-Hx  - Builder's threadHide this!Advertise here!
Dx Blame ST - Builder's thread - post pictures, reviews and comments here please. destroyer X Solid State 1874 28th August 2017 10:53 PM
group buy for DX Blame MKIII Hx PCBs ByronInPortland Group Buys 252 13th May 2016 05:14 AM
Dx Blame MKIII Supercharged will soon be released destroyer X Solid State 346 22nd April 2014 04:01 PM
Group By: DX Blame MKIII Hx boards ByronInPortland Group Buys 9 19th July 2011 08:21 AM
Dx Blame MKII, an obvious evolution from the Dx Blame ES/ST destroyer X Solid State 4 25th September 2010 07:41 PM
Copyright ©1999-2017 diyAudio
