Dx Blame MKIII-Hx  - Builder's thread
Old 7th January 2012, 02:27 PM   #711
destroyer X is offline destroyer X  Brazil
destroyer X's Avatar
Default It is much better ... congratulations, you hava fixed a lot o things
But several other things remained unchanged:
- Supply condensers can go up
- Lettering can have same size....small size
- 10 ohms resistor remained vertical
- Too much holes for the input capacitor is still there
- 150 ohms resistor is too much big
- Power emitter resistors too much big
- Big supply filter condensers continue too much low in the layout...touching screws
- Output resistor continue inside the coil
But the overall image is looking much better this way you have done.
Thank you,
Carlos
Dx unbeatable amplifiers; https://www.youtube.com/watch?v=u4tGBiqMnzQ
Old 7th January 2012, 02:33 PM   #712
meanman1964 is offline meanman1964  Belgium
meanman1964's Avatar
About the resistor in coil it is yellow so it must and can be soldered under the board.About the emiter resistor it is the size of a standerd white one I also can take the radial types.The 150 Ohm resistor is a 3 watt type.
Old 7th January 2012, 06:56 PM   #713
Default I see... the standard white one.
That floating resistor, the 150 ohms, can be a small resistor...it is an overkill to use such a big one...well..this does not harm the amplifier...it is just a waste of money and space into the board.
Keep it if you want...will not be bad.
Your board is looking great.
regards,
Carlos
Old 8th January 2012, 03:14 PM   #714
BMW850 is offline BMW850  Netherlands
BMW850's Avatar
If you apply the correct supply voltage to the amplifier when the output bias is turned down to minimum then you can start setting up your amplifier.
Using Carlos' method.
Power down and insert a 100r in place of the +ve rail fuse. This 100r could be soldered permanently across the fuse holder terminals so that all you need to do to set up the amp is remove the fuse.
Can someone tell me how many Watts the 100R resistor should be?
I also need a 100R in place of the -ve rail fuse I supose.
I only need insulation (see picture) for the 3 TO220 housings on the big heatsinks, I don't know the name
Next weekend I test the amplifier, then I have all de parts also for the light bulb tester.
Rudy
Itís not what you know, but who you know ďand where they areĒ
Old 8th January 2012, 04:06 PM   #715
Vigier is offline Vigier  Netherlands
It's called "isolation bushing" or "washer bushing" I think..
Old 8th January 2012, 05:05 PM   #716
BMW850, how many do you need?
Old 8th January 2012, 05:16 PM   #717
BMW850's Avatar
10 pieces but I need to order multiple items.
Thanks for asking, I appreciate that.
Please can someone tell me how many Watts the 100R resistor should be, then I can place the order
Rudy
Old 8th January 2012, 06:10 PM   #718
blistard is offline blistard  Netherlands
Hello BMW 850, where do you order these components?
Old 8th January 2012, 06:27 PM   #719
BMW850's Avatar
OKAPHONE ELEKTRONIKA
Rudy
Old 8th January 2012, 07:59 PM   #720
BMW850's Avatar
Just a few photos so you all can see how far the construction now is
Please can someone tell me how many Watt's the 100R resistor should be, then I can place the order
Rudy
Dx Blame MKIII-Hx  - Builder's threadHide this!Advertise here!
Dx Blame ST - Builder's thread - post pictures, reviews and comments here please. destroyer X Solid State 1874 28th August 2017 10:53 PM
group buy for DX Blame MKIII Hx PCBs ByronInPortland Group Buys 252 13th May 2016 05:14 AM
Dx Blame MKIII Supercharged will soon be released destroyer X Solid State 346 22nd April 2014 04:01 PM
Group By: DX Blame MKIII Hx boards ByronInPortland Group Buys 9 19th July 2011 08:21 AM
Dx Blame MKII, an obvious evolution from the Dx Blame ES/ST destroyer X Solid State 4 25th September 2010 07:41 PM
