Dx Blame MKIII-Hx  - Builder's thread
Closed Thread
Old 30th December 2011, 09:16 PM   #691
vargasmongo3435 is offline vargasmongo3435  Puerto Rico
vargasmongo3435's Avatar
Send a message via Yahoo to vargasmongo3435
Mister Calos
I wish a wonderful New Year in Brasil have fun and enjoy,but pass the key if you been drinking, take care my friend.
vargasmongo3435
Old 31st December 2011, 02:54 AM   #692
canonnica is offline canonnica  Canada
Originally Posted by vargasmongo3435 View Post
My dear friend cononnica I also have the same problem with my first board and I found out that my PC has a faulty GND problem so after I switch to my PC gamer desktop all of those noises were gone not sure what is your case, maybe is an input device problem, or lose GND maybe input cables need to be shielded, hey I'm about to buy those toroidal transformers from Antek, ok bro maybe you will figure out your humming sounds problems son or later. Thanks for sharing your finish product and have a wonderful Happy New Year bro, take care.
vargasmongo3435
Hi Juan, thanks for sharing ideas. The tests I did to establish the 3 types of noise I'm facing are as follows:
For noise type #3: Amplifier alone, speakers connected, nothing connected to the input, amp is the only powered-on device on the room; result = very slight humming that can be heard both from the midbass and tweeter from my 2-way loudspeakers. Even when the input connectors are shorted to (lifted) ground.
-> This is the one that will make me sweat. I guess I will need to open the chassis and revise the wiring.
For noise type #2: As soon as I connected my DVD player, without even any signal. DVD player is connected to TV which is conected to Cable-TV; result = huge hum from a ground loop. This one has been solved by grounding my Cable-TV entry point.
For noise type #1: Amplifier alone, speakers connected, nothing connected to the input, a TV is powered-up at about 1 meter from amplifier, TV is on the same power outlet as the amp; result = static-like noise that comes either from stray radiations emitted by electron cannon or by induced noise in the primaries through power-entry.
I'll shoot them one by one... and will post my findings
Martin
Old 3rd January 2012, 01:49 PM   #693
Talking A SIMPLE VIDEO OF MY HOBBY
Hello guys!
I made a video a couple of weeks before a completed the build of both boards you know also I print out a layout of Alex MM and Miguel Nabuco they are my favorites I just want it to show you is not to replace mister Alex MM board, his board is good still, maybe in the future I want it to order the board to see how it looks, and this is part of my hobby too and is a lot of brain entertainment for myself,I hope you like the video guys sorry for my horrible English is not perfect but hey! nobody is perfect lol.
http://www.youtube.com/watch?v=Y1sO-...ature=youtu.be
vargasmongo3435
Old 4th January 2012, 05:15 PM   #694
meanman1964 is offline meanman1964  Belgium
meanman1964's Avatar
Carlos,
As you know I'm busy with making a new layout for the MKIII HX high Power.Vigier,has asked me to use 4 pairs of output trannies and I did so.It's gonna be a double layer board and you can choose if you want to power up the voltage section separately or not.But I've one question regarding that 10 OHM resistor for lifted ground still needed or not?
Old 4th January 2012, 05:35 PM   #695
destroyer X is offline destroyer X  Brazil
destroyer X's Avatar
Default I do think we should give people both options
The ones believe it as a need, will use it....the ones do not believe will replace the resistor by a wire link....or will make an insulated link soldered in the board copper side.
regards,
Carlos
Restriction removed ; ttps://www.youtube.com/watch?v=3ioyOjAzDt0; https://www.youtube.com/watch?v=uFcnddpe3MU
Old 4th January 2012, 09:21 PM   #696
Carlos,
Need your opinion about the layout
Old 4th January 2012, 11:42 PM   #697
Vigier is offline Vigier  Netherlands
Hi meanman,
I sent you an email with my compliments & comments on the layout.
regards, Joris
Old 5th January 2012, 12:31 AM   #698
Default Here you have my comments about
Watch the video...shows image and sound and is more complete than to be typing a long message,
You have asked...here is the answer. - YouTube
regards,
Carlos
Old 5th January 2012, 09:05 AM   #699
Yes, I know the layout has some mistakes will take care of them.I want to show you the basic idea of my layout.Gonna make the changes you suggested Carlos thanks for your opinion.
Old 5th January 2012, 12:28 PM   #700
Carlos,
I did study Alex his layout and quess what not everything is aligned
Closed Thread
Dx Blame MKIII-Hx  - Builder's threadHide this!Advertise here!
Dx Blame ST - Builder's thread - post pictures, reviews and comments here please. destroyer X Solid State 1874 28th August 2017 09:53 PM
group buy for DX Blame MKIII Hx PCBs ByronInPortland Group Buys 252 13th May 2016 04:14 AM
Dx Blame MKIII Supercharged will soon be released destroyer X Solid State 346 22nd April 2014 03:01 PM
Group By: DX Blame MKIII Hx boards ByronInPortland Group Buys 9 19th July 2011 07:21 AM
Dx Blame MKII, an obvious evolution from the Dx Blame ES/ST destroyer X Solid State 4 25th September 2010 06:41 PM
