#641 | |
![]() Regards, Rudy
It’s not what you know, but who you know “and where they are” |
#642 | |
Oh, and your coil is 1000 times too small, according to the silk screen on the board (2.2mH) Brian. |
#643 |
and stay in place even if you hit it with a hammer.
I have drilled larger holes to the coil, and the pad, the island to solder was increased in size scratching using a knife..the a lot of solder keep the thing in place.... yeah.... a little bit exagerated. This coil is "just in case".... in normal use it does nothing.... we can even use a wire jumper in it's place in most of the cases.... because of that...it is not that critical, the number of turns and diameter can be different. In some amplifiers we use to correct overshots...not in this amplifier...it is stable.... if no broadcasting station is transmitting nearby the amplifier or speaker cables, then it will not face troubles...if cables are not too much high in capacitance and length then no problems too...if speaker crossover is not that crazy...then everything gonna be all right.... in other words, in "normal set up", you will not need the coil. There's a lot of thinks we include in audio amplifiers "just in case".... analogy is the air bag...they are included in your cars "just in case".... normally they will not be used.... these things are there for care, for caution. Bypass capacitors are there for the same reason... they will operate stopping oscillations..but only if oscillations starts... not having rail instabilities or transistors going unstable, then these parts will not work.... also zobel filter is another case, the input RF capacitor is one more... rail condensers and so on. In other words...if you coil has thick wires or thin wires... there's no problems about If coil turns is smaller or bigger..then no troubles Unstable amplifiers needs more care than this one...this is a Blameless with make up, from Doctor Self.... the man! regards, Carlos
Sons visiting uncle charlie; http://www.youtube.com/watch?feature...&v=5T76qsvZrdw; http://www.youtube.com/watch?v=Hb_wolQGU5Y Last edited by destroyer X; 16th December 2011 at 10:32 PM. |
#644 |
Okay, this is clear, then I make the diameter 8 mm, as described meanman1964.
The smaller the diameter, the stronger the coil. Tomorrow I will again the coil winding Regards, Rudy
#645 |
I am not able to re invent the powder without smoke...these things are validated in the daily practice...everybody uses 2.2uH.... 9 in 10 amplifiers use this value...was proven that work fine in most of the cases.....i made the choice copying what Self did and others did... a little bit more or less will not harm the amplifier operation... audio amplifiers use to have tolerances... the supply has more or less 10 percent... resistors are 5 percent or 1 percent, condensers can operate in 30 percent more voltage and transistors can be substituted by several other types...there's not all that precision we think.
You can change if you want and if you need, in special based in the fact that is there "just in case"..... so, we never know if the "case" is a bigger case or small case...we do not know what is the case or it's size. You know...i am not that different that others...i bother myself to tweak the amplifier to read 0.003% THD..... a foolish as when we connect the speakers the distortion they produce is in the order of 2 to 5 percent to the better ones...so... my concerns are something like blowing in the wind. This is the most wonderful thing in analog amplifiers... is that they are not that precise..we can make mistakes. Critical are differential current, VAS topology and VAS current, output topology and output stand by current, Miller capacitor value and your choices how to feed the stages, bootstrap?... CCS?... mirrors?... these things changes performance...small modifications within rational tolerances does not bother the audio amplifier overall performance..will not be the output coil value that will increase of decrease the audio quality in a stable system (without terrible errors described in earlier posts) regards, Carlos
Sons visiting uncle charlie; http://www.youtube.com/watch?feature...&v=5T76qsvZrdw; http://www.youtube.com/watch?v=Hb_wolQGU5Y Last edited by destroyer X; 16th December 2011 at 11:00 PM. |
#646 |
Sorry guys I haven't post anything lately Christmas in Puerto Rico is crazy but still on it and still loving this delicious amplifier lot of fun!
to Dx Blame MKIII Hx "clank!"...
#647 |
The L of the output R//L is definitely not 2 to 3mH, no matter what anyone shows in BOMs nor on PCBs.
1uH is normally a good guide, but DX recommends higher than this. I tend to use a 15mm diameter mandrel and wind on 8T to 12T of 1.2mm or 1.4mm diameter enameled copper wire. If I wanted low milli-ohms and non vibrating I would use 1.6mm diam wire and wind 3 layers, each with 3T, for a total of 9T. Bind it with some strong sewing thread. Then soak it in three applications of nail varnish. |
#648 |
My post failed to attach a smiley, to show I was only joking. Of course it's meant to be 2.2 micro(u)H
Much has been written that suggests it should be no greater than 1uH. Brian. |
#649 |
Hello,
I'm interested in this amp, but have a few simple new guy questions:
Thanks, Mason |
#650 |
This thread you are was made to talk about MKIII (three) Hx ... or MKIII Hx
Dc Blame ES Dx Blame ST Dx Blame MKII Dx Blame MKII Supercharged These ones constitutes four models served by the same board...there are instructions and charts to instruct you about what parts should be replaced to assemble each one of these 4 different models, all them can be built using the same pcboard...the pcboard is good to all 4 models....there are codified parts using part numbers (R1, C2 and so on) and these ones are interchangeable parts... they are specific parts that corresponds to different values in accordance to each specific amplifier you select to assemble....all other parts are standard and the value is printed into the pcboard layout silk screen. About power of each amplifier, specifications and overall performance, you should read Dx Blame ES and Dx Blame ST thread (both amplifiers in the same thread)...and developments are in this same thread...you should search for MKII Supercharged using forum search button and you should read them all to know more details about. These amplifiers ( Dx Blame ES, Dx Blame ST, Dx Blame MKII, Dx Blame MKII Supercharged) are previous models,they are not the last ones...they were the base to evolute..the reference..they sound excellent too. .... the MKIII Hx is the evolution of these previous models..these ones, the Blame series, was created, built, tested, a pcboard layout was made, a board was manufactured, a board was assembled and tested, we had group buy, several boards where sold at cost price inside group buy...people have assembled, and now we are in a more modern unit while many guys are still listening and enjoying the Blame series (Dx Blame ES, Dx Blame ST, Dx Blame MKII and Dx Blame MKII Supercharged)... the we had the MKIII and MKIII Hx that is the subject of this thread we are now producing off topic (against rules...here is to talk about MKIII Hx only) You should read some...to know what happened in this forum these last years...i have readed this forum (all forum, entire solid state section...since the beginning) and i did that four times...you should, at least, search for threads with these names i have informed and read them all prior to post questions. Here you have what you need: * Please visit and open all files in the Kinghost...read instructions, if something is not clear or missed, then try forum search button or send messages to: nanabrother@hotmail.com There's no boards for sale...you have to etch your own board. Please take some time to read in advance to post questions...we have worked a lot to write instructions in the diyaudio to avoid us to be repeating to each new member that arrive.... and all this work was made to serve you and all beginners that are giving us the pleasure to be interested in the Dx Corporation amplifiers (not a real business, it is a union of the best wide world audiophiles only) regards, Carlos
Sons visiting uncle charlie; http://www.youtube.com/watch?feature...&v=5T76qsvZrdw; http://www.youtube.com/watch?v=Hb_wolQGU5Y Last edited by destroyer X; 18th December 2011 at 10:46 PM. |
| Dx Blame ST - Builder's thread - post pictures, reviews and comments here please. | destroyer X | Solid State | 1663 | 14th February 2013 04:38 AM |
| Dx Blame MKIII Supercharged will soon be released | destroyer X | Solid State | 341 | 7th December 2012 04:50 AM |
| group buy for DX Blame MKIII Hx PCBs | ByronInLawrence | Group Buys | 247 | 5th December 2012 12:05 AM |
| Group By: DX Blame MKIII Hx boards | ByronInLawrence | Group Buys | 9 | 19th July 2011 07:21 AM |
| Dx Blame MKII, an obvious evolution from the Dx Blame ES/ST | destroyer X | Solid State | 4 | 25th September 2010 06:41 PM |
