Dx Blame MKIII-Hx  - Builder's thread
Closed Thread
Old 15th December 2011, 08:48 AM   #621
destroyer X is offline destroyer X  Brazil
destroyer X's Avatar
Default Oh!...that's terrible Byron.... connected to negative lead?
Not a good choice the condenser factory made..... unbelievable error from the industry..these can must be insulated from the condenser poles.... yeah.... retarded brain solution... a surprise to me these things...i have never found a unit like that.
Well...i am glad you have found the problem...now think in a solution to keep your lovely condensers..they look good and i know you love them...you may find the way..insulating it with rubber, wood, or any other insulating material...not to loose them.
regards,
Carlos
Restriction removed ; ttps://www.youtube.com/watch?v=3ioyOjAzDt0; https://www.youtube.com/watch?v=uFcnddpe3MU
Old 15th December 2011, 11:45 AM   #622
R.I.P.
On reading Byron's warning I immediately went upstairs and checked my studded Sikorels.
They too have stud and -ve connected.
S+M
SIKOREL 105
B41570-A9108-q
regards Andrew T.
Old 15th December 2011, 01:43 PM   #623
BMW850 is offline BMW850  Netherlands
BMW850's Avatar
The components that you are seeing now on the board are soldered now, 1 amplifier is now almost finished I wait with the other board, first to test this one.
Now I make the light-bulb tester, I have all the components.
The small heat sinks are on the way and the M3 machine tap is also ordered for tapping into the large heat sinks.
On the photo you can see how I have solved the 220uF 100 volts caps issue
The capacitor legs, I scrolled Teflon tube.
Rudy
p.s. I order also 2x Roederstein MKT1813 1,0uF 100V
Itís not what you know, but who you know ďand where they areĒ
Last edited by BMW850; 15th December 2011 at 01:48 PM. Reason: Roederstein MKT1813 1,0uF 100V
Old 15th December 2011, 02:00 PM   #624
a.wayne is offline a.wayne  United States
Sin Bin
850,
How are you stabilizing/supporting those caps, a dab of silicone underneath ...?
Old 15th December 2011, 02:02 PM   #625
BMW850's Avatar
Originally Posted by a.wayne View Post
850,
Yes, and a tire wrap.
Rudy
Edit: pictures are made with mobile phone
Old 15th December 2011, 02:08 PM   #626
R.I.P.
Similarly, the two pairs of big caps will be stronger and stiffer if you tie wrap each of the pairs.
One 4leg mounting is far better than the sum of two 2leg mountings. Especially so when the legs are farther apart.
regards Andrew T.
Old 15th December 2011, 02:18 PM   #627
currentflow is offline currentflow  United Kingdom
You have a way with words, Andrew Thank goodness mostly audio engineers / enthusiasts will be reading this!
currentflow
Old 15th December 2011, 02:54 PM   #628
R.I.P.
For the football fan in you I will explain further.
Take a pair of goalposts at each end of the pitch.
Bring one set to the other end. Mount them solidly in the ground about 3m (10') behind the normal goal posts.
Now tie a rope to the crossbar and find out how much load is required to pull over that one set of 2leg structure.
Now repeat the experiment for the other 2leg structure.
Sum the results from both experiments.
Now a thinking exercise. Tie the cross bars of both the undamaged goal posts together. Now estimate the force required to pull both sets of 2 leg structures over.
It should be roughly double the result from each of the first two experiments.
The two sets of relocated goalposts are are 3m apart and they are ~2.5m high.
Brace the uprights at the ends together with a big X frame 2.5m high by 3m wide.
You now have a 4leg structure. Still 4 connections into the ground still the same upright dimensions.
Now the next thought experiment.
What force applied to the crossbars will be required to pull over the 4leg structure? Will it be less than the sum of the two 2leg structures or the same or more than the sum of the 2leg structures?
Finally, stiffness
Apply a force via the rope that is only half the force necessary to pull over the single 2leg structure.
How far does the cross bar move?
Now apply that same force to the second goal post. How far does it move?
Now apply that sum of two half value forces to the 4leg structure with the X bracing attached.
How far do the goalposts/crossbar move?
Is it less or same or more than for the 2leg structures?
I think if I set that as a topic for an experiment, physical and mental, in a science or technology class for 12year olds, they could give something approaching the correct conclusions.
Tie wrap around a pair of close coupled capacitor cans is the equivalent to adding the bracing to the goalposts.
The +ve and -ve legs of the two capacitors are the equivalent to the bottom ends of the uprights of the goalposts.
regards Andrew T.
Old 15th December 2011, 03:30 PM   #629
ByronInPortland is offline ByronInPortland  United States
ByronInPortland's Avatar
I don't understand. Is this American football, or European football, a.k.a. soccer?
Old 15th December 2011, 03:33 PM   #630
R.I.P.
Currentflow declares United Kingdom and shows a Union Jack.
I suppose that means I mean football.
regards Andrew T.
Closed Thread
Dx Blame MKIII-Hx  - Builder's threadHide this!Advertise here!
Dx Blame ST - Builder's thread - post pictures, reviews and comments here please. destroyer X Solid State 1874 28th August 2017 09:53 PM
group buy for DX Blame MKIII Hx PCBs ByronInPortland Group Buys 252 13th May 2016 04:14 AM
Dx Blame MKIII Supercharged will soon be released destroyer X Solid State 346 22nd April 2014 03:01 PM
Group By: DX Blame MKIII Hx boards ByronInPortland Group Buys 9 19th July 2011 07:21 AM
Dx Blame MKII, an obvious evolution from the Dx Blame ES/ST destroyer X Solid State 4 25th September 2010 06:41 PM
