Dx Blame MKIII-Hx - Builder's thread - Page 61 - diyAudio
Old 6th December 2011, 12:30 AM   #601
vargasmongo3435's Avatar
Send a message via Yahoo to vargasmongo3435
Talking I guess is natural
Cool wow well I didn't know much about editing is just natural for me I guess lol :
Old 7th December 2011, 02:38 AM   #602
I spent the whole evening tuning some buzzing noise issues... This amp is the only device of my system that's grounded. It created problem when connecting to "floating ground" devices. My biggest problem is when I connected the DVD player to my DAC using the coaxial cable, it gave quite a buzzing sound.
I finally found that the buzzing came from the coaxial video signal from my provider (that goes to the TV set, then my DVD player is connected to the TV, a nice ground loop here). I had to ground that cable both at the entry point in the house and behind the TV receiver. It's all good on that side now.
I know that I've grounded my amp for safety purpose, but why do the consumer integrated amps, TVs and all of this stuff doesn't have a ground? to avoid those loops and save on support? how can all of this be safe and not our DIY project without a ground?
Martin.
Old 7th December 2011, 04:49 PM   #603
BMW850 is offline BMW850  Netherlands
BMW850's Avatar
Default Single-Layer Air Coil Calculator
Here you have a Single-Layer Air Coil Calculator:
Pronine Electronics Design - Single-Layer Air Coil Calculator
Rudy
Itís not what you know, but who you know ďand where they areĒ
Old 8th December 2011, 02:14 AM   #604
wintermute's Avatar
OT posts removed as requested.
Any intelligence I may appear to have is purely artificial!
Some of my photos
Old 11th December 2011, 07:51 PM   #605
ByronInPortland's Avatar
Unhappy problems with power supply, any suggestions?
I'm all finished building, meaning everything is put together. (see first picture) Two things are not working right, which may or may not be related.
One, is that I'm getting more voltage from one power supply than from the other. I have a dual power supply. Each uses 40-0-40 secondaries. But I'm measuring 43-0-43 on both. That's probably not a big deal, but after rectification I'm getting 110VDC across the positive and negative of one PS, and 161VDC across positive and negative of the other PS. This shouldn't even be possible (86*1.42=122). Furthermore, this voltage is not divided evenly between positive and ground (100VDC) and negative and ground (62.5VDC). I checked every diode (MUR860) and get exactly 0.403 ohms and no conductance in the two directions for all 8 diodes. Note that all these measurements were taken with no load - that is, positive and negative rails were open, so no current was flowing. They were also taken without filter caps in place. I don't know if that effects my measurements. Please see the second picture for a diagram of the PS, without filter caps.
The other problem is that I keep blowing mains fuses (5amp slo-blo) on start-up, even with my soft start. They don't blow as long as I don't have the filter caps hooked up. I don't know if my soft-start is not working properly, or if it is just not "soft" enough. Maybe it needs a larger timing cap?
Any help is greatly appreciated.
Old 11th December 2011, 08:08 PM   #606
AndrewT is online now AndrewT  Scotland
Disconnect everything from the transformers.
Test the transformers individually with nothing connected to them.
Now connect mains power via a bulb tester and test the transformers individually again.
Once you know the transformers are wired up correctly, add a bridge rectifier. Test again. Add the other bridge rectifier. Test again.
Add one pair of smoothing caps. Test again.
Add a second pair of smoothing caps. Test again. Are you getting the message?
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 11th December 2011, 08:26 PM   #607
destroyer X's Avatar
Default Andrew T instructions are fine Byron
Give it a try ... follow his instructions.
regards,
Carlos
Full throotle amplifier manufacturing; https://www.youtube.com/watch?v=iEXaSSlMEBg, Sample Dx Classic https://www.youtube.com/watch?v=fVvFrwl92RU
Old 11th December 2011, 08:33 PM   #608
Are you sure your polarity is right on both sides? By looking at your picture, it seems you got one amp card backwards. I'm not sure of the polarity of your srew-type caps, but you definitely got one amp card backwards. See pic below.
Old 12th December 2011, 08:08 PM   #609
BMW850's Avatar
The capacitor 2.2 uF (63V) what is a good capacitor for this position?
And is this capacitor important for the sound of the amplifier?
Rudy
Old 12th December 2011, 08:27 PM   #610
Byron, nice work! I can see why it took a little longer. Thx for posting a pic. I was looking at the same chassis and torids. I'm looking forward to your review after it breaks in. I'd love to have a set of these boards...........
The stuff you don't know always humbles us.........
Dx Blame ST - Builder's thread - post pictures, reviews and comments here please. destroyer X Solid State 1810 27th July 2016 06:34 PM
group buy for DX Blame MKIII Hx PCBs ByronInPortland Group Buys 252 13th May 2016 05:14 AM
Dx Blame MKIII Supercharged will soon be released destroyer X Solid State 346 22nd April 2014 04:01 PM
Group By: DX Blame MKIII Hx boards ByronInPortland Group Buys 9 19th July 2011 08:21 AM
Dx Blame MKII, an obvious evolution from the Dx Blame ES/ST destroyer X Solid State 4 25th September 2010 07:41 PM
Copyright ©1999-2017 diyAudio
