Dx Blame MKIII-Hx  - Builder's thread
Closed Thread
Old 21st November 2011, 11:55 AM   #531
destroyer X is offline destroyer X  Brazil
destroyer X's Avatar
Default Here is the video
You can play your MKIII Hx in Biamp mode - YouTube
regards,
Carlos
Restriction removed ; ttps://www.youtube.com/watch?v=3ioyOjAzDt0; https://www.youtube.com/watch?v=uFcnddpe3MU
Old 24th November 2011, 07:37 AM   #532
Default MKIII Hx is a high power amplifier...this may look great
but also big will be the problems this will create to speakers...they usually are not rated to so huge power.
Observe the chart of power (specifications) published in this thread, in the group buy thread and also in the MKIII thread...there you have power to several output impedances correlated to transformer power.... so, observe the power you will have as a result of your impedance and your transformer.
Knowing your power..then select your speaker driver's this way:
60 percent of the total power will go to the woofer
30 percent of the total power will go to the midrange driver
10 percent of the total power will go to the tweeter driver
This is the normal distribution of power you will perceive inside commercial speakers...a 100 watts speaker uses a 60 watt woofer, a 30 watt midrange and a 10 watt tweeter...this is the normal, to save money in the production line.
So, knowing your power you can know your needs about speaker rating.
The first trouble is that when you clip your amplifier...and people does that without perceive.... some modern music are already clipped, or distorted in the master.... then harmonics will be generated because the square wave...and all harmonics will be a bomb thrown into the tweeter that usually is the first that gonna die.... then knowing that, use 4 tweeters, the power rating will be very high, as you gonna add four tweeters power rating and also the series resistance used to reduce the HIGHER ACOUSTIC PRESSURE that is consequence of 4 drivers playing instead of a single one...use series parallel..two tweeters in series together other two tweeters in parallel... a series resistance will go from 16 to 32 ohms in order to balance the sound to result acoustically flat or flat to your ears.
Here is my friends video that create me panic..... that tweeter would die easy and fast...MKIII Hx can put out several amperes..it is an eartquake!
Nani destroy my woofers magazine - YouTube
And here my comments about the ferrofluid fashion thing:
- "The idea may be fine...that tweeter is fine...but the ferrofluid cooling is not a good idea as that oil damps the tweeter, it is a sticky grease thing surrounding the coil that damps the movement..it cools down, that oil helps..but sonics will not be all that brigth because the sticky thing...try another model, , air cooled, soft some, silky dome, lightweigth dome, but avoid the ferrofluid. knowing your supply power we can know power..tweeter is 10 percent total power... 30 watts tweeter is good to 300W amp"
You have a picture about too.
regards,
Carlos
Old 24th November 2011, 01:59 PM   #533
vargasmongo3435 is offline vargasmongo3435  Puerto Rico
vargasmongo3435's Avatar
Send a message via Yahoo to vargasmongo3435
Uhm didn't know that my friend so has to be "dry" lol alright then air cooled, soft some, silky dome, lightweight dome, got it bro.
regards
vargasmongo
Old 24th November 2011, 03:39 PM   #534
BMW850 is offline BMW850  Netherlands
BMW850's Avatar
Hello everyone,
I have now almost all parts but still have a few questions and hope that I get an answer, because it is confusing what I read on the printed board and the part list.
Also the R26 A to J, 0R47 5 Watt non inductive resistors only fit on one side, the hole is to small on 1 side see picture
Have 20 new 2R2 0.25 watt resistors purchased because the 1 watt resistors were too big, they do not fit in the holes of the print.
Is it wise to use 0.25 W resistors for R24 A to J 2R2 because there on the printed board I read 1 Watt??
Now it is these resistors, they are in part list:
R27 2 pieces 10R 5 Watt --ŗ I can’t find them on the board
R28 2 pieces 15R 3 watt. --ŗ I've tried and 1 watt did not fit in the holes of the print, what wattage I need for this one?
Please tell me what the right wattages are for those resistors R27 / R28 / R24 A to J.
And YES, the heat sinks arrived this week for testing, maybe I need bigger ones we will see, only the aluminum blades are on the wrong side
What is the best way to screw thread tapping into aluminium
Rudy
Itís not what you know, but who you know ďand where they areĒ
Old 24th November 2011, 04:17 PM   #535
BMW850's Avatar
I still want to see first if everything fit on the board, and nothing soldered yet.
Rudy
Old 24th November 2011, 04:26 PM   #536
meanman1964 is offline meanman1964  Belgium
meanman1964's Avatar
You may drill the holes larger or do you mean the RM?
Old 24th November 2011, 04:26 PM   #537
canonnica is offline canonnica  Canada
Bimmer, many hole are too small... You will need to enlarge them. Luckyli for me, being a hobbyist I had many small drill bits and a hand driver. Look for drill bits that are numbered (not in fraction of inches nor in millimeters, but really numbered) See this chart: CHART_PDF. Hobby shops (model train, etc.) have them.
For the 10R 15W, they're in parallel with the output air-cored coil. It should be soldered under the board (don't include them in the coil as this will change the inductance value).
Martin.
Old 24th November 2011, 05:17 PM   #538
I didn't meant 15W but 5W... See this pic below for my installation of it.
For taping into aluminium, make sure you got the correct drill bit size, and ABSOLUTELY get yourself some aluminium cutting oil. There are many charts on the net for the drill bit size vs tap size. You want to find a specialized shop where they sell machine-shop tooling for that.
Put cutting oil on the drill bit and a drop on the surface to be cut, use a drill press, it helps make the holes perfectly perpendicular to the plane.
When taping, make 1/2 turn foreward, then do 3/4 turn backward, then go 1/2 turn deeper, then back 3/4 turns and so on. Put cutting oil in the hole and also on the drill bit with a hobby paint brush.
Cutting oil makes difference between success and a stuck-and-then-broken tap, which is a PITA. BTDT
Old 24th November 2011, 06:04 PM   #539
BMW850's Avatar
Thanks canonnica for the replies but still have a few questions
1. R28 2 pieces 15R 3 watt. I've tried and 1 watt did not fit in the holes of the print, what wattage I need for this one?
2. Have 20 new 2R2 0.25 watt resistors purchased because the 1 watt resistors were too big, they do not fit in the holes of the print.
Because "I see 0.25 watt" on the pictures to other builders?
On the second picture you see 1 watt.
Rudy
Old 24th November 2011, 06:27 PM   #540
Talking Size of the 2.2 ohms I use 1/2W
Hey bro!
Well I'm using 0.5 watts resistors but also you can use 0.25 watts, I'm using 1/2 watt just for insurance the size of the resistor I'm using is about 10mm, and since is a bit bigger than the silk screen you have to bend it a little closer to the resistor frame, maybe this will help.
regards
vargasmongo3435
Last edited by vargasmongo3435; 24th November 2011 at 06:35 PM. Reason: a bit more info
Closed Thread
Dx Blame MKIII-Hx  - Builder's threadHide this!Advertise here!
Dx Blame ST - Builder's thread - post pictures, reviews and comments here please. destroyer X Solid State 1874 28th August 2017 09:53 PM
group buy for DX Blame MKIII Hx PCBs ByronInPortland Group Buys 252 13th May 2016 04:14 AM
Dx Blame MKIII Supercharged will soon be released destroyer X Solid State 346 22nd April 2014 03:01 PM
Group By: DX Blame MKIII Hx boards ByronInPortland Group Buys 9 19th July 2011 07:21 AM
Dx Blame MKII, an obvious evolution from the Dx Blame ES/ST destroyer X Solid State 4 25th September 2010 06:41 PM
