#501 |
What a space, what an oppertunity to spread the transistors physically! I'd have tried to give eacch transistor much more Sq/Inch to give each a better buffer for thermal transients.
Negative Feedback: The Need for Speed |
#502 |
The pic showing Kapton appears as pink. I thought Kapton was clear.
Is that isolator coated with some other material on one, or both sides? Thin mica with Thermal compound on both sides is a very good heat conductor. Very few film based insulators can match it's Thermal performance. Choose carefully if you need good Thermal performance. Even fewer film based insulators can improve on thin mica+goop. Kapton film on it's own is a flat surface that will not conform to the imperfections of the heatsink nor the device. Plain smooth Kapton requires Thermal compound on both faces just like mica. Last edited by AndrewT; 20th November 2011 at 02:11 PM. |
#503 | |
Looks like it is designed for blown tunnel cooling. At the maximum power expected they are more like PA amplifier PCBs, where blown cooling is the norm. Last edited by AndrewT; 20th November 2011 at 02:16 PM. |
#504 | |
I just didn't get that from the chosen heatsink - if it would have been these high-density fin designs I'd have assumed active cooling.
#505 |
Your concern is valid.
The PCB is designed for tunnel cooling, if high power must be dissipated. That tall heatsink is quite unsuited to obtaining good heat dissipation efficiency with the PCB. |
#506 |
^^^I guess you know this from your last 1kw/ch@1ohm build
![]() ![]() Err, ahh i guess you mised the xtra outputs or the 7" tall caps ...... room for the soft start, regulated supply and the 8.5x4 " transformer ..
#507 | |
#508 |
I will use this sink
#509 | |
Sil-pads come in a few different varieties. The most common is a silicone rubber material reinforced with fiberglass. A different version has 2 thin silicone rubber layers sandwiching a layer of polyimide film. Many manufacturers use sil pads because they don't require grease to perform to spec (which makes assembly quicker and easier). |
#510 | |
Nice setup for fans, fans will not work for me due to the noise, i will have a fan to cool the case if temps escalate , but only for those brief moments. Also i do not like the heat concentration such a setup creates ....
| Dx Blame ST - Builder's thread - post pictures, reviews and comments here please. | destroyer X | Solid State | 1665 | 17th June 2013 08:04 AM |
| Dx Blame MKIII Supercharged will soon be released | destroyer X | Solid State | 341 | 7th December 2012 04:50 AM |
| group buy for DX Blame MKIII Hx PCBs | ByronInLawrence | Group Buys | 247 | 5th December 2012 12:05 AM |
| Group By: DX Blame MKIII Hx boards | ByronInLawrence | Group Buys | 9 | 19th July 2011 07:21 AM |
| Dx Blame MKII, an obvious evolution from the Dx Blame ES/ST | destroyer X | Solid State | 4 | 25th September 2010 06:41 PM |
