Dx Blame MKIII-Hx  - Builder's thread
Closed Thread
Old 5th November 2011, 11:14 AM   #341
Junie is offline Junie  Philippines
Hello Patrick, I suggest to have a solder pads on both side of output trannies for easy mounting on the heatsink.
Old 5th November 2011, 12:07 PM   #342
canonnica is offline canonnica  Canada
Originally Posted by destroyer X View Post
Cannonica - MP3/4 players, Ipods and so on, use to have lower audio output level, exception is if you use the line out output jack ... having low level in the input you will not reach full power, then you should reduce the gain resistor connected to the second differential transistor base .... the feedback one ... the one you have connected to the output line through a 47K resistor.... Sultans of Swing is also one of my main test songs.... thank you very much by your support, confidence in Dx amplifiers and also your enthusiasm.... pictures are nice..thank you, go ahead posting...more!
No problem on that side Carlos, I got a Cambridge Audio iPod dock that pumps the data stream and a modified Beresford external DAC with volume control as a "preamp". On my iPod, there's only lossless compressed stuff, "Replaygain" is however applied to the content for audio normalization. Direct iPod audio out is for testing purpose only.
Martin.
Old 5th November 2011, 12:33 PM   #343
meanman1964 is offline meanman1964  Belgium
meanman1964's Avatar
The pads are plated trough
Old 5th November 2011, 03:58 PM   #344
vargasmongo3435 is offline vargasmongo3435  Puerto Rico
vargasmongo3435's Avatar
Send a message via Yahoo to vargasmongo3435
Default Godd idea solder mask ot top of the board!
Really good idea to have solder mask on top of the main power trainies, "sorry for my horrible English" but good, I just place top solder mask, that is more flexibility for builders hell yeah.
Old 5th November 2011, 04:11 PM   #345
Default Through pad top solder
Well I guess I got it figure out on the "Through pad"
Old 5th November 2011, 04:23 PM   #346
Wink X-ray board simulate top solder
Also I put it on X-ray to simulate how the top solder look.
Last edited by vargasmongo3435; 5th November 2011 at 04:26 PM. Reason: wrong picture doubles
Old 5th November 2011, 06:23 PM   #347
Well done Juan, and additional holes for the screws to fix the board properly. at the moment in my build I put spacers at the bottom secured by rubber cement. See below for my suggested holes location.
Old 5th November 2011, 06:42 PM   #348
Default thanks!
Well done Juan.
I try to help the best I can for ideas.
Old 5th November 2011, 06:56 PM   #349
Talking Support for the weight of the board
Super Junie Super! more ideas really nice, I hope meanman64 like it too,
I just place some holes in areas of the board where the weight has more effect.
keep coming ideas hell yeah! thanks Junie!
Last edited by vargasmongo3435; 5th November 2011 at 06:58 PM. Reason: wrong image
Old 5th November 2011, 07:09 PM   #350
By the way, what is the correct diameter of the holes that support the board?
Closed Thread
Dx Blame MKIII-Hx  - Builder's threadHide this!Advertise here!
Dx Blame ST - Builder's thread - post pictures, reviews and comments here please. destroyer X Solid State 1874 28th August 2017 09:53 PM
group buy for DX Blame MKIII Hx PCBs ByronInPortland Group Buys 252 13th May 2016 04:14 AM
Dx Blame MKIII Supercharged will soon be released destroyer X Solid State 346 22nd April 2014 03:01 PM
Group By: DX Blame MKIII Hx boards ByronInPortland Group Buys 9 19th July 2011 07:21 AM
Dx Blame MKII, an obvious evolution from the Dx Blame ES/ST destroyer X Solid State 4 25th September 2010 06:41 PM
