Dx Blame MKIII-Hx  - Builder's thread
Old 31st October 2011, 06:23 PM   #311
BMW850 is offline BMW850  Netherlands
BMW850's Avatar
Hi Rudi,
These are very very cheap "you might almost think they are fake"
Rudy
Itís not what you know, but who you know ďand where they areĒ
Old 31st October 2011, 06:40 PM   #312
Rudi_Ratlos is offline Rudi_Ratlos  Germany
Rudi_Ratlos's Avatar
No fake, Rudy, but these series of capacitors is abandoned by NICHICON.
That is why the price is that low!
Best regards - Rudi
Old 31st October 2011, 06:59 PM   #313
BMW850's Avatar
Thanks Rudi
Tonight I will order 8 pieces, and hope they are good quality caps
Rudy
Old 31st October 2011, 07:10 PM   #314
destroyer X is offline destroyer X  Brazil
destroyer X's Avatar
Default Dear Juan Vargas ... our friend Meanman is studying what to do
soon we gonna have some return from him, and them this gonna be published and i will send you email informing for sure.
He is thinking to make some small modifications... about clearance to heatsink (on board ones) ... some tracks may be enlarged .... suggested transistor model numbers will be printed into the silk screen .... board will be painted red both sides... and so on.
Also Byron can open a second round if he decided to do .... this way we gonna have more boards available in a matter of a couple of months to come.
No circuit change.... the problem related on board heatsink (clearance to produce room to a bigger ones, or to install them in the main heatsink, or to fix them below the board) will be solved too.
Meanman is free to make small modifications, making interface with Alex mm or changing himself together the board manufacturer company that usually produce tests in his layouts .... he will suggest some ideas ... but for sure the amplifier will be the same unit with minor modifications into the pcboard layout.
As i had that surprise... the heatsinks not large enough ... then i decided to make a step back, or to work in the most safe side... assembling the board myself prior to deliver them to forum folks... to avoid surprises i will be the first to assemble and test the circuit assembled into the same board you will receive.
regards,
Carlos
I am alive and healthy folks... for Brazil only product: https://www.youtube.com/watch?v=6A_g8uPHHO4: https://www.youtube.com/watch?v=DTXl1eEgygk
Old 1st November 2011, 06:04 PM   #315
Junie is offline Junie  Philippines
Default Testing in progress
I made a Toggle switch using 555 timer, circuit can be found in other website, also i finished Ostripper softstart hook it up altogether for checking and it works the way it supposed to be, very happy with the outcome. I like those "circle green light"
Here are some pics of my progress, messy but satisfying.
Old 1st November 2011, 09:01 PM   #316
Default Nice work Junie.... i would like to show Juan Vargas pictures
He will use 54 volts supplies....he bought a larger heatsinks as you can see and installed the CCS and VAS into the larger heatsinks.
Uploaded with ImageShack.us
Good.
regards,
Carlos
Old 1st November 2011, 10:33 PM   #317
Woody1911a1 is offline Woody1911a1  United States
Junie , when you say that , i'm assuming you used a 555 timer in some way as a relay circuit because those switches are only rated at 2A ? am i correct and if so , please tell me how . i love those switches but their max amp rating is such a limiting factor .
cheers Woody
Old 2nd November 2011, 01:45 PM   #318
canonnica is offline canonnica  Canada
VAS & CCS Heatsinks; is it best to raise them from the board surface for the convection effect to be more effective?
Old 2nd November 2011, 02:11 PM   #319
cheers Woody
Hey Woody, yeah 555 as pre driver and used SSR instead of Relay.
More info can be found here: Toggle ON / OFF Switch
Old 2nd November 2011, 02:42 PM   #320
vargasmongo3435 is offline vargasmongo3435  Puerto Rico
vargasmongo3435's Avatar
Send a message via Yahoo to vargasmongo3435
Talking vargasmongo personal layout changes "heat sink'
Today a did some changes on my layout, I change the heat sink for a taller ones and the silk screen too, of course this is Alex MM layout don't get me wrong that is the man! well I got to keep looking analising and all that, I hope you guys like my ideas, "I hope so" lol , alright guys have a good one.
Dx Blame MKIII-Hx  - Builder's threadHide this!Advertise here!
Dx Blame ST - Builder's thread - post pictures, reviews and comments here please. destroyer X Solid State 1874 28th August 2017 09:53 PM
group buy for DX Blame MKIII Hx PCBs ByronInPortland Group Buys 252 13th May 2016 04:14 AM
Dx Blame MKIII Supercharged will soon be released destroyer X Solid State 346 22nd April 2014 03:01 PM
Group By: DX Blame MKIII Hx boards ByronInPortland Group Buys 9 19th July 2011 07:21 AM
Dx Blame MKII, an obvious evolution from the Dx Blame ES/ST destroyer X Solid State 4 25th September 2010 06:41 PM
