Dx Blame MKIII-Hx - Builder's thread - Page 24 - diyAudio
Old 12th October 2011, 02:21 PM   #231
vargasmongo3435's Avatar
Send a message via Yahoo to vargasmongo3435
Originally Posted by ByronInLawrence View Post
I already asked this question, but I'll try one more time.
I like the profile for the heatsinks for the MJE15030 and MJE15033 transistors Alex drew in the silkscreen, but can't find them. Does anyone know of such heatsink? If not, what is everyone using?
-Byron
I'm not sure but I think this are the ones,
TO-220 Heatsink Voltage Regulator Isolation Kit 4 pcs | eBay
regards
vargasmongo
Old 16th October 2011, 12:20 AM   #232
ByronInPortland's Avatar
Unhappy My board is not working
I suspect I damaged something on the board, but don't know where to start looking. Here is the whole story:
  1. I thought I had my power supply working (which I later learned was not the case). I fired up the board for the first time without a bulb tester, which I hadn't built yet.
  2. I heard a brief crackling. I didn't see or smell smoke. I carefully checked for hot components and didn't find any, so I continued.
  3. I was trying to adjust the bias, but the board was not behaving as I expected. I don't remember what tipped me off, but I re-checked my power supply.
  4. I had two diodes on my rectifier flipped! I was sending AC through my filter caps and then, presumably, to the board. My multimeter measured this as about the correct DC voltage from rails to ground.
  5. I'm pretty confident I fixed my power supply, which measures ~59VDC positive-ground and ground-negative, and ~118VDC positive-negative. No AC voltage.
  6. I built a bulb tester and resumed setting the trimmer resistor. I found I could not get the voltage drop across the 100ohm test-resistor up to 4.4VDC.
  7. I thought that maybe I'm not supposed to have a jumper from signal ground to main ground, so I tried cutting it. I also thought maybe I needed an 8R resistor from speaker-out to ground. The included chart shows all the permutations, and the voltages I got for them.
  8. Typical test was: 1) put the light bulb in line and hook up the test leads. 2) Turn on. The bulb would glow brightly, then gradually dim. With the 8ohm resistor between speaker out-and ground it never dimmed completely. 3) Measured voltage would jump around at first, then slowly move to some final value, which is the value I recorded. 4) Bypass the lightbulb. Measured voltage would jump a bit, then settle on its new value.
  9. I removed and tested the trimmer resistor, and it works fine from 0 to 1020R.
At no point in the building or testing did I ever see or smell any smoke. I would frequently search for hot components, and never found any except those center transistors, which are now heatsinked.
I would appreciate any suggestions about where to start troubleshooting. I've not started on the second board yet, but have at least 2 of everything.
Old 16th October 2011, 09:00 AM   #233
Discard the 50W dummy load. It is drawing current to Audio Ground due to the output offset. No useful information in there as far as I can tell.
The open output and shorted input shows output offset. Can this be adjusted towards zerovolts?
Thankfully the offset is not near rail voltage. I think that is telling us that the outputs are not blown. Can you check current is flowing through every emitter resistor of the output stage. List all the Vdrops.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 16th October 2011, 12:34 PM   #234
Junie is offline Junie  Philippines
I'm suspecting a wrong value resistors mate.
Old 16th October 2011, 06:20 PM   #235
destroyer X's Avatar
Default My Blame amplifier is not working uncle charlie!
Yep... sometimes this happens;
My Blame amplifier is not working uncle charlie! - YouTube
regards,
Carlos
Full throotle amplifier manufacturing; https://www.youtube.com/watch?v=iEXaSSlMEBg, Sample Dx Classic https://www.youtube.com/watch?v=fVvFrwl92RU
Old 17th October 2011, 03:51 AM   #236
Thumbs up I found a problem
I don't know if it's the problem, but it's something. Two of the supplemental power supply filter caps - the big ones on either side of the board - are inconsistent. Sometimes they measure spot-on, and sometimes they give crazy values which are all over the place. They did this on the board, and after I took them off. Monday, I'll put back all the other components I removed to check and try again. And I'll try Andrew's suggestion.
I do have a question: There is a resistor right next to the trimmer pot. On my schematic I named it R21. Alex put the value 680R on the board, but Carlos' schematic shows 1200R. I used 1200R. I verified the value of it and all the resistors anywhere near that trimmer pot with my multimeter. Should I have used a lower value there, especially considering my <64V rail voltage? Presumably, that value of 1200R was chosen for 64V rails. If getting rid of these filter caps doesn't solve the problem, that will be plan B.
Thank you, everyone, for your suggestions.
-Byron
Old 17th October 2011, 02:34 PM   #237
Hi mister Junie I read on the forums and the 1.2k resistor is not showing on mister Alex MM board it has 680 ohms will that make a difference?
regards
vargasmongo
Old 17th October 2011, 04:07 PM   #238
This resistor value is determined by the bias transistor chosen. See the attached pictures. I don't remember on what forum / page I picked these pics, but they come from DX-man himself about the Hx amp.
Martin.
Old 17th October 2011, 04:38 PM   #239
Martin.
Thanks! I already have the NPN transistor MJE15030 so it should be 1.2KR instead of 680R. oh boy!
regards
vargasmongo
Old 17th October 2011, 05:00 PM   #240
Thumbs up 680 or 1.2K
Yes! it is 1.2K I just want it to make sure thanks!
Dx Blame ST - Builder's thread - post pictures, reviews and comments here please. destroyer X Solid State 1810 27th July 2016 05:34 PM
group buy for DX Blame MKIII Hx PCBs ByronInPortland Group Buys 252 13th May 2016 04:14 AM
Dx Blame MKIII Supercharged will soon be released destroyer X Solid State 346 22nd April 2014 03:01 PM
Group By: DX Blame MKIII Hx boards ByronInPortland Group Buys 9 19th July 2011 07:21 AM
Dx Blame MKII, an obvious evolution from the Dx Blame ES/ST destroyer X Solid State 4 25th September 2010 06:41 PM
Copyright 1999-2017 diyAudio
