Dx Blame MKIII-Hx  - Builder's thread
Closed Thread
Old 17th May 2014, 05:30 PM   #2131
still4given is offline still4given  United States
still4given's Avatar
Hi Carlos,
I'm just glad to see you coming back around. I worried we had lost your presence here. I will be praying for success in your weight loss. As we get older our health becomes increasingly more important and we can no longer ignore it. I'm trusting that you will eventually desire to release you future designs to the DIY community once again.
Blessings, Terry
Old 17th May 2014, 07:07 PM   #2132
destroyer X is offline destroyer X  Brazil
destroyer X's Avatar
Default Thank you Terry..... i cannot leave this forum
I have made some good friends here.. and each one of them worth more to me than 1000 of these less pleasant ones that sometimes appear......also i am crazy for audio.
There's another problem, i have 200 Fets, and i have to figure out how to make them sound the way i like.
I am developing some new ideas..... maybe gonna share some of them.
I am already feeling some age effects...memory is failing.
There's a class A that i am interested to try.....and i can burn some Fets trying to make them sound nice... due to my stock....there's also a tube here, Bigun sent me...and i have to use it and this one can produce the tube alike harmonics we like..... this is something boiling in my mind.
regards,
Carlos
Restriction removed ; ttps://www.youtube.com/watch?v=3ioyOjAzDt0; https://www.youtube.com/watch?v=uFcnddpe3MU
Old 17th May 2014, 07:41 PM   #2133
Bigun is offline Bigun  Canada
Bigun's Avatar
wow, that's quite a lot. What kind do you have - are they all the same ?
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 17th May 2014, 07:59 PM   #2134
a.wayne is offline a.wayne  United States
Sin Bin
Carlos , Fets, Tooobs, Class-A ................
Old 17th May 2014, 08:23 PM   #2135
Default Yep... a lot..... here you have some.
IXFH26N50
FQA19N20C
FQA12P20
FQA34N20
IRFP064N
FPQ50N06
IRF9530
IRF1405
BUZ11A
And some biigger ones lost in another box...i have to search to find them.
Almost all them are new...there are some few BJTs included in this box too.... the component leads, or "legs" are cut short to avoid them to break when you bend it... a way i found when i was very young to avoid the component to break right at the limit such that I could not solder a wire to use the component.... a tradition, a use that I developed and I could not get rid of it even though the new components normally do not need it.
regards,
Carlos
Old 17th May 2014, 08:30 PM   #2136
Default Thank you A. Wayne
I feel that you are happy.
Thanks,
regards,
Carlos
Old 17th May 2014, 09:04 PM   #2137
Bigun's Avatar
I see you have a nice selection !
Before you make too many plans for those devices I assume you will test them first to see if the FETs are still working and not destroyed by static electricity.
Old 17th May 2014, 09:16 PM   #2138
Default They are fine..... and easy to check with multimeter
This will not be the problem....problem is to make them sound the way i want.
regards,
Carlos
Old 10th April 2015, 10:01 PM   #2139
Default A friend asked me to tune the MKIII to use as subwoofer amplifier
He gonna use an active filter (op amps)... and this amplifier will operate from DC to 150 hertz... he asked me to put it to 4 ohms and distortion he asked less than 0.010%....i made it to 0.005%... also the input gonna be 1.2 Volts RMS to achieve full power.... Power achieved was 455 Watts RMS at 4 ohms and distortion at 45 hertz not more than 0.005%
Miguel Nabuco (Mitchel) gonna use two Leach Amplifier channels only to Mid range frequencies.
He gonna use 4 Dx Super A to High and Super High Frequencies... all then gonna be optimized to his demands...
Here you can see his work to the subwoofer:
https://www.youtube.com/watch?v=1I3phnr7ihQ
https://www.youtube.com/watch?v=nK-p2k198RE
Schematic attached for you to see...optimized to 45 hertz....frequency response drop abruptelly above 2 Kilohertz even if you inject full bandwidth noise on it..input capacitor filters.... high frequencies goes to ground... just in case.
Marked in green are parts removed or changed in value.
He may produce this stuff to sell in Brazil..but inside gonna be Godzilla amplifier from Dx.
regards,
Carlos
Old 16th April 2015, 02:10 PM   #2140
Default This MKIII sounds like mine one
maybe better due to speakers.
I do think all MKIII has the same destiny... to bright as stars.
https://www.youtube.com/watch?v=8FjTX010YU0
regards,
Carlos
Closed Thread
Dx Blame MKIII-Hx  - Builder's threadHide this!Advertise here!
Dx Blame ST - Builder's thread - post pictures, reviews and comments here please. destroyer X Solid State 1874 28th August 2017 09:53 PM
group buy for DX Blame MKIII Hx PCBs ByronInPortland Group Buys 252 13th May 2016 04:14 AM
Dx Blame MKIII Supercharged will soon be released destroyer X Solid State 346 22nd April 2014 03:01 PM
Group By: DX Blame MKIII Hx boards ByronInPortland Group Buys 9 19th July 2011 07:21 AM
Dx Blame MKII, an obvious evolution from the Dx Blame ES/ST destroyer X Solid State 4 25th September 2010 06:41 PM
