Dx Blame MKIII-Hx - Builder's thread - Page 174 - diyAudio
Old 12th July 2013, 11:34 PM   #1731
Look at my DX MKIII.
48012_626667174012371_347453836_n (1) - Download - 4shared - Newton Costa
1002295_626667637345658_992110443_n (1) - Download - 4shared - Newton Costa
><>Newton J. Costa<><
Old 13th July 2013, 02:18 PM   #1732
It looks nice Newton. Do you have a chassis planned for it?
Old 13th July 2013, 02:28 PM   #1733
meanman1964's Avatar
radioFlash,can you send me a pdf file of your layout?
Old 13th July 2013, 04:03 PM   #1734
meanman1964,
I've been working on populating the board. I noticed I had a missing track for R08A to R08B. I also increase the hole sizes for some of the electrolytics. Attached is a PDF with some of these corrections.
File Type: jpg radioFlash DXMKIII PCB partially populated.jpg (161.3 KB, 270 views)
File Type: pdf DX Blame MKIII HX output 2013-07-13-a.pdf (597.6 KB, 131 views)
Old 13th July 2013, 04:23 PM   #1735
vargasmongo3435's Avatar
Send a message via Yahoo to vargasmongo3435
mister radio flash that is what I call, "talent" a really well put it together a truly DIY concept art, thumps up sir
Juan
Old 13th July 2013, 04:37 PM   #1736
wiljj78 is offline wiljj78  Philippines
wiljj78's Avatar
Juan
Yess very nice indeed... But i'm thinking on Q12 and Q10 Heatsink are enough to handle the heat if R13 used 22R??
Old 13th July 2013, 07:59 PM   #1737
radioFlash not yet, but I'm thinking of a model.
Old 13th July 2013, 08:09 PM   #1738
Can see other photos here.
Flickr: Newton J. Costa's Photostream
Old 13th July 2013, 08:54 PM   #1739
Thanks for your kind comments vargasmongo. As for the the heatsinks on Q12 and Q10, they're rated at about 7C/W. I'm not sure what the power dissipation of Q12 and Q10 are, so I'm not sure if that's sufficient.
Old 15th July 2013, 02:11 AM   #1740
I finished installing all the components on the board using my layout and turned on the amp using the lightbulb tester and no load connected and a +/- 40V power supply. The lightbulb flashed as the caps charged and then went out, but I see +35V on the output without any input signal. The oscillocope shows DC. The good news is it provides another "learning opportunity" for me!
So far, I've done the following in-circuit checks with the amp powered off:
* Set VR midway
* No short to heatsink for output transistors
* Inspected soldering and did continuity check--did not find any shorted tracks
* Verified correct transistors installed in correct locations
* Diode check Q12 ok (b to c, e)
* Diodes 1n4007, BAV21 ok on diode check
* Checked all transistors, no shorts
* Did not note any unusually hot components or observe any obvious physical damange such as scorched/smoking resistors or capacitors
* Checked resistor value R10-correct 2k2
* Checked orientation of electrolytics-ok
* Checked continuity of rails to OP transistors: only saw continuity with collectors as expected
Dx Blame ST - Builder's thread - post pictures, reviews and comments here please. destroyer X Solid State 1810 27th July 2016 05:34 PM
group buy for DX Blame MKIII Hx PCBs ByronInPortland Group Buys 252 13th May 2016 04:14 AM
Dx Blame MKIII Supercharged will soon be released destroyer X Solid State 346 22nd April 2014 03:01 PM
Group By: DX Blame MKIII Hx boards ByronInPortland Group Buys 9 19th July 2011 07:21 AM
Dx Blame MKII, an obvious evolution from the Dx Blame ES/ST destroyer X Solid State 4 25th September 2010 06:41 PM
Copyright 1999-2017 diyAudio
