#1621 |
Mr. Wanye I,m sorry but my budjecty doesn,t allow me to drink eggnog. I get BOMDED on one drink only LOL
#1622 |
Sorry Fella,s I always like to mix cricuit up,,I could really use a glass of johnnie walker GREEN. LOl
#1623 |
You have an entire 1000 square meters appartment inside my heart... do not need to pay for use it... you just cannot leave it.
Happy new year Evette...you are never off topic to me. ![]() regards, Carlos
Sons visiting uncle charlie; http://www.youtube.com/watch?feature...&v=5T76qsvZrdw; http://www.youtube.com/watch?v=Hb_wolQGU5Y |
#1624 |
I just ordered some 2SA968B & 2SC2238B from Littlediode (UK). I don't know what to expect as if they're genuine, but I'll give them a try.
These will take the spots held by MJE15030&31 at the CCS, VAS & driver positions. Mart. |
#1625 |
But i found them fragille...i had some of them burned...well.... read my name, Destroyer x means extra Destroyer....this is what i use to make, to burn parts.
2SC4793 and counterpart are better... see the capacitance and compare.... this one 20pf and 2SC2238 is 25pf.... watch the maximum frequency..the same...watch power...the same... 4793 does not need insulators..also the number is higher, means it is more modern. I understand that more modern does not mean better.... about BD139/140, the higher numbers, the most modern ones are worse...it can happens with these units we are discussing too..but i have listened both...and for sure 2SC4793 sounds better...matches better to the amplifier voltage..i have tried one into high voltage unit...was an old model.... Troyan i think. Already ordered?.. then good luck to you...i suggest you to order the 2SC4793 and complementary too. regards, Carlos
Sons visiting uncle charlie; http://www.youtube.com/watch?feature...&v=5T76qsvZrdw; http://www.youtube.com/watch?v=Hb_wolQGU5Y Last edited by destroyer X; 31st December 2012 at 02:46 PM. |
#1626 |
Carlos, I've imported SPICE models for them as well and they don't give any better result than the MJE1503x. The fT for the pair you suggest are not well matched, 100MHz vs 70MHz, so I'm not sure they will be good drivers.
The best pairs I've found so far are Toshibas 2SA968B & 2SC2238B and Sanyos 2SA1011 & 2SC2344. I should get my old Toshibas within a few weeks, I'll post observations when I install them
#1627 |
What are you trying to improve with the change , sonics, stability , drive, bandwidth ?
What if we use the outputs instead ...? |
#1628 |
What will happens there is not something to worry about, unless this appear into the capacitance in between transistor leads.
This mismatch will appear into harmonics that will produce interference into VHF radio band.... will not bother humans. regards, Carlos
#1629 |
Mr. Carlos Who said we are all human,,just ask my wife. LOL Evette
#1630 |
Because no one believe.
Ahahahahahah! regards, Carlos
| Dx Blame ST - Builder's thread - post pictures, reviews and comments here please. | destroyer X | Solid State | 1663 | 14th February 2013 04:38 AM |
| Dx Blame MKIII Supercharged will soon be released | destroyer X | Solid State | 341 | 7th December 2012 04:50 AM |
| group buy for DX Blame MKIII Hx PCBs | ByronInLawrence | Group Buys | 247 | 5th December 2012 12:05 AM |
| Group By: DX Blame MKIII Hx boards | ByronInLawrence | Group Buys | 9 | 19th July 2011 07:21 AM |
| Dx Blame MKII, an obvious evolution from the Dx Blame ES/ST | destroyer X | Solid State | 4 | 25th September 2010 06:41 PM |
