#1561 |
In the seventies american cars had theire positive battery pole hooked on the chassis of the carbody.JBL had woofers in that time the red speaker connection as negative and the black connection as positive.When you hook those driver on a todays amp and don't turn the connection the cone will move inverse.I think that's why it is important how you wind your coil.
#1562 |
I'm not sure to get it completely, but is it only relevant when the resistor is located in the core of the coil?
#1563 |
Why have the coil , is this the possible slewing we see on canonnica's amplifier can it be removed ?
Anyway Merry Xmas guys , Joe check under your tree , only 24 as requested .. ![]()
#1564 |
Wayne I believe this coil has something to do with possible ringing of the amplifier at or above 200khz,, It,s acting as a damper . It also helps to stabilize the amplifier. Also reduces the damping factor. My christmas tree died I forgot to give it water. Joe
#1565 |
The most important thing is BMW850 didn't find his MKIII sound nice and after he rewind the coils he said the sound improved.There are some things we can't explain and maybe it's good to have some basic rules like how to wind your coil even if it's just for your peace of mind.
#1566 | |
Steve |
#1567 |
It had something to do with the input and output of the coil.I've ask Hugh Dean to give an explanation here.I've checked different commercial amps and all the coils are winded the same direction as I stated.
#1568 |
where can I get for this PCB layout?
http://www.facebook.com/?ref=home#!/...?id=1398304239 |
#1569 |
to the main thread where the amplifier is shown first time....and there you will have layout to etch the pcboard at your own home.
regards, Carlos
Dx Super A - Brazil - Layout Zimmer; http://www.youtube.com/watch?v=yxpYnUA6Bj0 |
#1570 | |
http://www.sg-acoustics.ch/analogue_...n_comments.pdf Thank you again for your kind response. |
| Dx Blame ST - Builder's thread - post pictures, reviews and comments here please. | destroyer X | Solid State | 1665 | Yesterday 08:04 AM |
| Dx Blame MKIII Supercharged will soon be released | destroyer X | Solid State | 341 | 7th December 2012 04:50 AM |
| group buy for DX Blame MKIII Hx PCBs | ByronInLawrence | Group Buys | 247 | 5th December 2012 12:05 AM |
| Group By: DX Blame MKIII Hx boards | ByronInLawrence | Group Buys | 9 | 19th July 2011 07:21 AM |
| Dx Blame MKII, an obvious evolution from the Dx Blame ES/ST | destroyer X | Solid State | 4 | 25th September 2010 06:41 PM |
