Dx Blame MKIII-Hx  - Builder's thread
Closed Thread
Old 22nd December 2012, 09:04 PM   #1541
destroyer X is offline destroyer X  Brazil
destroyer X's Avatar
Default This diode adds capacitance
You have no more the original capacitance....now you have the original value plus the diode junction capacitance....naturally slew rate changes a lot.
regards,
Carlos
Restriction removed ; ttps://www.youtube.com/watch?v=3ioyOjAzDt0; https://www.youtube.com/watch?v=uFcnddpe3MU
Old 22nd December 2012, 10:14 PM   #1542
CBS240 is offline CBS240  United States
CBS240's Avatar
Originally Posted by canonnica View Post
As suggested by Vostro, I've clamped the Miller cap and now rail sticking is gone. Here are some scope traces that shows some nice curves under normal conditions as well as during clipping and hard clipping.
Frequency and amplitudes are shown on the graphs. Don't worry about the ripples visible on the traces, I think I have a parasitic problem into the scope...
For thse who doesn't like the square waves, note that these tests have been made at 40v p-p.
Even under hard clipping, never the amp has gone into oscillations, so that's good. I also join the exact schematic of the amp tested. The load was a 6r/300W resistor. The bias was set at 16mV between two output resistors.
BTW, I burned my speaker protection relay, under heavy clipping at 20KHz, the speaker-prot has triggered... and the contacts went into smoke (D'UH).
Enjoy!
There appears to be some rail sticking on the positive rail, worse at light clipping. There also seems to be an instability as the signal comes out of clipping. Something is ringing there. The output seems to be a a bit slew limited. Do you have any series resistance between the function generator and the input (filter)? This will limit the SR of the square wave input. The bootstrap cap C9 has over 7V across it. When the output aproaches the positive rail, the bias on the MJE15033 CCS will be something like +62V on the emitter, +61.4V on base, but +70V on the collector. This might not be good for the MJE15033. What is the need for the bootstrap if you have a CCS to load the VAS?
All the trouble I've ever been in started out as fun......
Old 22nd December 2012, 10:27 PM   #1543
bonfis is offline bonfis  United States
Default Alternative solution to sticking?
I did a simulation of shorting the VAS emitter resistor R22 as suggested by Carlos. This eliminated the sticking problem as least in simulation. I'm going to try the real thing tomorrow and will report back.
Steve
Old 23rd December 2012, 01:27 AM   #1544
Default Thank you CBS240
Giving us a helping hand.
I forgot the diodes in the output.... i have not imagined someone would be interested to clipping performance as in my imagination people will operate below clipping....but this is one more that i learn...people is interested in these details.
Living and learning...i have never imagined that... really...never!
Ahahahahha!.. i am really laughing about that.... this is super precision...how dirty is the dirt...how messy is the mess....i do think we must run away from dirt or mess...not to study them...applied to clipping the same logics.....well....maybe i am wrong.,,,if before clipping i do think it is interesting to study.... but after clipping?... will people listen the clipping?... will be listening while clipping...will listen distortion by a pleasure?..... strange.
I have not watched how bad the clipping is....i have just inspected the performance till the amplifier clip... as people may reduce volume when perceiving clipping.... you know?.... what is the interest to know how an automobile engine is destroyed if you go in the red strip in the speedometer.. after the maximum RPM reached...engine will be without good lubrication..will be going to destruction.... i do not want to know...i just will avoid to destruct the engine and will operate in the blue safe region....well... this is my way of thinking.
I thought i was a little bit mad.... or little bit crazy..with one brain screw loosen.... i see that i am healthy... in comparison with people with concerns that way.
Merry Christmas boys...enjoy your life....huck the clipping!
Carlos
Old 23rd December 2012, 03:51 PM   #1545
CBS240's Avatar
Clipping behavior is a good test of unconditional stability. Eventually someone will crank it up and when they do, there should be no chance that an instability caused by that action might create failure of the output stage. I don't listen to clipping, but an amp should be able to drive a clipped signal for a period of time, or limit the input signal so as never to actually clip. This amp is close, a few minor tweeks ought to do it. This is where I take an educated guess as to where the issues are and do some trial & error.
Old 23rd December 2012, 04:29 PM   #1546
Default Result of shorting R22
I tested the amp with R22 (VAS emitter resistor) shorted. The bad news is this did not eliminate the sticking to the negative rail. The good news is that it increased the output 6 volts rms before clipping begins. So the amp can now be driven harder without getting into clipping. Doesn't seem to be any downside to the change otherwise. I also looked closely at the waveform coming down from the positive peak. I didn't see any evidence of the glitch (ringing?) that Cannonica is observing. There are I believe several differences between my MK III and his including changes to the input stage emitter degeneration resistors (100R) and a higher global feedback factor. Perhaps the increased feedback is attenuating the glitch?
I'm interested in the comment by CBS240 about C9. I have to admit that I don't really understand it's function so I'm confused about it's relevance to the glitch problem. Perhaps someone would be kind enough to enlighten me.
Old 23rd December 2012, 05:03 PM   #1547
canonnica is offline canonnica  Canada
That's exactly my motivation...
The glitch on the positive side getting out of clip seems in the input stage. I'm trying to figure it out in the sim.
M.
Old 23rd December 2012, 05:07 PM   #1548
regards,
Carlos
Yes, the spec sheet (UF4004) says 17pF, so it's rather low...
Old 23rd December 2012, 05:57 PM   #1549
Vostro is offline Vostro  South Africa
Vostro's Avatar
I still advice to keep the diode in place, if you want: trial and error reducing the miller cap, that's what I would do.
The diode should not audiblily affect slew before clipping, if it affects slew after clipping, thats a mute point.
But interesting, I'll also do some research and listening tests.
I don't have access to my workbench till January, I can't think of how to get rid to the positive side glitch.
Hoping the more experienced members, will pitch in with a solution .
I would not remove the resistor (R22) by VAS, it has a function, side effect might be small reduction in max output Vpeak, but this difference is not audible.
4R7 in diagram is small, I use bigger resistor, but depends on VAS current. (so I guess I loose even more form my max output Vpeak)
@bonfis, what transistor are you using for VAS.
Kind Regards
Old 23rd December 2012, 06:01 PM   #1550
Vostro's Avatar
@Mr Carlos, hope you have a great festive season.
I also have a question, is your VAS current (Iq) set by the current source, or by the bootstrap?
regards
Closed Thread
Dx Blame MKIII-Hx  - Builder's threadHide this!Advertise here!
Dx Blame ST - Builder's thread - post pictures, reviews and comments here please. destroyer X Solid State 1874 28th August 2017 09:53 PM
group buy for DX Blame MKIII Hx PCBs ByronInPortland Group Buys 252 13th May 2016 04:14 AM
Dx Blame MKIII Supercharged will soon be released destroyer X Solid State 346 22nd April 2014 03:01 PM
Group By: DX Blame MKIII Hx boards ByronInPortland Group Buys 9 19th July 2011 07:21 AM
Dx Blame MKII, an obvious evolution from the Dx Blame ES/ST destroyer X Solid State 4 25th September 2010 06:41 PM
