#1491 | |
1.) it adds a real resistance to the load seen by the previous stage. If the load without the base stopper is real and +ve, then the stopper just adds some resistance. if the load is a -ve resistance then the stopper can and should make the source see a +ve resistance load, i.e. converts the load from -ve to +ve, if the Rb is selected big enough. 2.) the stopper when very close to the base junction reduces the inductance seen by the junction and the parasitics around that junction that can create an oscillator if an uncontrolled inductor is attached to that base lead. I am very unskilled at this AC circuit theory, so I hope what I have stated above is close to fact. I welcome anyone to correct any errors I have stated above, or to reword either of my two statements to make them technically more accurate. |
#1492 | |
The important value is Vre. This is discussed and explained at length in many Threads by many Members. It is detailed in D.Self's papers and by Cordell and many other renowned amplifier Designers. Set the output stage to optimal ClassAB bias, using the "voltage" method described by Self, both in his amp design books and in the web pages of his site. |
#1493 | |
After inserting the 56R stoppers I measured THD as I adjusted the bias upward. THD came down steadily until about the 60 mv point (measured across 2 emitters) where it pretty much leveled off. THD was reduced to about 10% of the amount measured at the recommended bias setting. I don't have a personal preference on bias I just follow the procedure of adjusting for minimum THD. My heat sinks seem to handle the idle current just fine so I'm happy. Steve |
#1494 | |
As Re goes down, Vre also goes down. This is because the internal resistance of the transistor becomes a higher proportion of the total emitter resistance. Optimal ClassAB biasing uses the voltage across the "external" emitter resistor. The "internal" emitter resistance cannot be measured by the Vre method. D.Self details this. |
#1495 |
Hi Mart-
Thanks for the charts. They agree very well with my measurements. BTW what simulation software are you using? |
#1496 |
I finally neglected my family, friends and responsibilities for a few hours and proceeded with the modifications
![]() Here what i've done: Replaced the 22 Ohms base-stoppers with 100 Ohms. Replaced the 180pF miller cap with a 100pF one. Increased the bias to 54mV cold (across both emitter resistors). Yes the high-bias stability was restored by increasing the base-stoppers as expected and as witnessed by bonfis. I did all of this with a lot of precautions. I started it first with resistors in place of the fuses and using the light-bulb in serie with the power cord. I did only one channel to be able to do an A-B comparison. If you do this mod and increase the bias, make sure you won't have cooling problems. Sitting idle for around 60 minutes, the heat-sink temperatures are 27C for the unmodified channel (4mV bias) and 37C for the modified one at 54mV bias. No adjustment is required concerning the DC offset, it hasn't changed. Now about the subjective impressions... I did only 30 minutes worth of comparing. I used recordings that are not overly compressed, 12-14dB worth of dynamics and some that only has 5-6dB of dynamics. As of now, I noticed pleasant differences. I will try to describe what I listened so it's hard to explain. And no i didn't do any double-blind tests as I don't personnally consider this necessary. The sound... or sonics as some says... The first thing that stands out is the slight attenuation of the middle-mids and high-mids. Like in the voice, electric guitar, snare range, they're less proemininent. On the unmodified channel, they tend to crush everything around them. Now they're more evenly blended. The second thing I noticed is an increase of clarity and definition of the highs. The cymbals are back and have a clearer sustain and brillance. It's probably due to the fact that they're not sent backwards by the middle-mids and high mids registers. Also the bottom end, the "roundness" of the sound is increased slightly. I would say that an better separation is listenable between the instruments because of the lack of confused (or confusing?) mids. Overall theses mods are keepers. Since I don't have a scope (yet??) I cannot confirm if any rigning or oscillations is present. But for sure, my listening observations correlate what was expected by lowering the odd-order harmonics (through increased bias). Some will probably say my observations are irrelevant because I always know which channel is playing and blahblahblah... too bad for them, they need to do that mod and test it by themselves then ![]() I think that it's a matter of taste, I guess some will prefer without the mods, some will prefer as modified and some others will need to have an in-between solution. I listened to that amp for a whole year as of now. I'm gonna modify the other channel and reinstate it its normal environment. Time will tell if it's a long-term keeper or if it's only an over-optimistic mod. ![]() If you feel comfortable doing this mod, please do so and share your impressions. Martin. |
#1497 | |
Thus in adjusting for optimal bias high value base stoppers should reduce the desired measured drop across the the external resistors. Thanks -Antonio |
#1498 |
I'm not as experienced as most here with audio,
But sadly its been my experience that my original expectations from design, don't match my final circuit in 'real world conditions'. For example, my last amplifier simulated at 0.001% THD 1-30kHz at 185W into 8R. So expectations were high, then I build the prototype and .... hehe problems. I also had to increase base stoppers, rather than increasing miller cap, or reducing gain. and make a number of small changes, all which took me further away from my expectations. My result for now is a amp that I like the sound of, and I guess thats what matters, Regards |
#1499 | |
Wow,
Thanks for taking the time to provide us with these updates Martin , very valuable input, now i have starting point .... ![]() Quote:
#1500 |
Vostro
I think simulators are great, and in your case can't you go back and add inductance to the base of the output transistors, and some load capacitance, possibly collector inductance as well to best match the observed parasitic oscillation? Imagine trying to do even very simplified analysis by hand, simulators can get you there but they need to be refined as you extract new infromation from the working circuit (or simplified if you are just trying to understand). Thanks -Antonio |
| Dx Blame ST - Builder's thread - post pictures, reviews and comments here please. | destroyer X | Solid State | 1663 | 14th February 2013 04:38 AM |
| Dx Blame MKIII Supercharged will soon be released | destroyer X | Solid State | 341 | 7th December 2012 04:50 AM |
| group buy for DX Blame MKIII Hx PCBs | ByronInLawrence | Group Buys | 247 | 5th December 2012 12:05 AM |
| Group By: DX Blame MKIII Hx boards | ByronInLawrence | Group Buys | 9 | 19th July 2011 07:21 AM |
| Dx Blame MKII, an obvious evolution from the Dx Blame ES/ST | destroyer X | Solid State | 4 | 25th September 2010 06:41 PM |
