Dx Blame MKIII-Hx  - Builder's thread
Old 5th December 2012, 06:35 PM   #1461
canonnica is offline canonnica  Canada
Originally Posted by AndrewT View Post
I don't follow.
I see % on the right hand vertical scale.
At the 0.1% level the harmonic for a 40Vpk signal (28.28Vac) should be 1/1000 or about 28mV.
The left scale shows values of voltage of 0.0003V (maybe 0.0002828), this is 0.3mV.
That to me seems to be a discrepancy factor of 100times.
Right scale is for THD only. Left scale is amplitude of individual harmonics. They<re not related, I just wanted the THD curve to be "close" to the others in the same graph.
When I look back at it, I notice that the scale on the right should be divided by 100... The amplitude scale on the left is correct as well as the THD curve itself, only the scale is wrong.
Old 5th December 2012, 06:46 PM   #1462
BMW850 is offline BMW850  Netherlands
BMW850's Avatar
I will do these plots for other resistor values and other powers as time permits
Martin
Martin, if you're done with the simulation I go ordering parts also the 56R.
Perhaps this is also interresting to see, how coil is wound: Fetzilla Build Documentation
Also tell us the maximum bias setting when you finish.
Rudy
Itís not what you know, but who you know ďand where they areĒ
Old 5th December 2012, 07:29 PM   #1463
Vostro is offline Vostro  South Africa
Vostro's Avatar
Maybe a nice addition, for future would be to add protection on amp main board.
Maybe at least short circuit and dc out ptotection.
Old 5th December 2012, 07:39 PM   #1464
vargasmongo3435 is offline vargasmongo3435  Puerto Rico
vargasmongo3435's Avatar
Send a message via Yahoo to vargasmongo3435
Just playing with the layout not completed yet, just ideas. please do not feel alarm not intended to replace mister Alex MM original design, just to see how it looks .
Juan
Old 5th December 2012, 08:00 PM   #1465
BMW850's Avatar
First lets Martin take its course and after that continue with the Dx Blame MK4-Hx.
Let's first ensure that the Dx Blame MKIII-Hx "sounds better"
Rudy
Old 5th December 2012, 08:05 PM   #1466
Thumbs up like it yes!
oh, I didn't know that wow! good...
Juan
Old 6th December 2012, 04:49 PM   #1467
I've made some more analysis varying the Rb and vBias and only vBias seems to alter the distortions behaviors. However as already mentionned, the recent simulations i've done demonstrate that a higher value of Rb seems to provide increased stability. In simulation it even permits to lower the miller comp cap without compromising the initial "advised" stability.
As an example, at 10KHZ, with Rb of 22 Ohms, the simulator struggles sometines to plot the oscilloscope trace as rigning appears on the positive side of the wave. Lowering Rb to 10 Ohms makes things worse. Increasing Rb to 56R or 100R erradicates that propblem.
Leaving Rb to 22 Ohms and decreasing Cdom also worsen the problem while increasing Cdom erradicates it as well.
Increasing Rb to 100 Ohms permits decreasing Cdom to 100pF (in place of the 180pF) without compromising stability. I can definitely conclude that there's some kind of relationship between those two. As I'm no engineer on that matter I can only report my observations and draw rough conclusions around it.
My plan is to open the real box and increase Rb to 100 Ohms, increase the bias and test it. One channel at a time. Then when my observations are donw, revalidate the behavior in simulator to eventually try to lower Cdom to 100 pF.
That will bring me exactly at the values advertized by Dr. Self in his base amplifiers.
Martin.
Old 6th December 2012, 05:06 PM   #1468
canonnica, do you mean this Rb? that is interesting, can you keep me updated of your finds I mean if you don't mind, I'm making this layout from Alex MM original design with just a few modifications same circuit just placing them with more space I always like the MKIII from Alex MM layout, but I don't have special equipments nor oscilloscope to check, well that is mister Carlos job I just like layout designs, but is good to know you are checking and find better ways that is good.
thank you
Juan
Old 6th December 2012, 05:17 PM   #1469
Yes the resistors you circled.
Old 6th December 2012, 05:34 PM   #1470
very good thank you, here is how it looks maybe is going to take me a few more days.
Juan
Dx Blame MKIII-Hx  - Builder's threadHide this!Advertise here!
Dx Blame ST - Builder's thread - post pictures, reviews and comments here please. destroyer X Solid State 1874 28th August 2017 10:53 PM
group buy for DX Blame MKIII Hx PCBs ByronInPortland Group Buys 252 13th May 2016 05:14 AM
Dx Blame MKIII Supercharged will soon be released destroyer X Solid State 346 22nd April 2014 04:01 PM
Group By: DX Blame MKIII Hx boards ByronInPortland Group Buys 9 19th July 2011 08:21 AM
Dx Blame MKII, an obvious evolution from the Dx Blame ES/ST destroyer X Solid State 4 25th September 2010 07:41 PM
