Dx Blame MKIII-Hx - Builder's thread - Page 117 - diyAudio
Old 22nd April 2012, 12:02 PM   #1161
I won't argue on subjective topics. I did my homework and came with objective results.
Refer to the image below...
The offset test was made with the signal input leads shorted. I did it both with the real physical 42pounds heavy amplifier, and with the simulator. BOTH gave the same results...
There IS a DC offset voltage at the input transistor's base. The input cap DO block this from getting back in your source.
By removing the cap, that DC offset will leak to the ground and its amplitude be altered thus changing the stability of the speaker-out's offset.
Furthermore if, like me, you have an input pot to control the input sensitivity, turning it will change the resistance of the circuit (input DC offset to ground) and will alter greatly the DC offset at speaker-out. Turning that input pot makes the speaker go in and out like crazy, I guess the output varies by many volts .
Do your own tests my friend... and you will see.
I got to report this because other people may be tempted to remove the input cap and they risk breaking something. This amp cannot run directly coupled to a source
Old 22nd April 2012, 01:28 PM   #1162
Canon,
well argued. Don't let them put you down when you have the evidence to support your conclusions and/or statements.
I would rather have music than broken equipment.
In my book "broken equipment" can never reproduce as well as working equipment.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 22nd April 2012, 01:31 PM   #1163
375mVdc of input offset across 47k indicates that a fairly high current is flowing from the base of the input transistor. It also indicates a low input impedance to the amplifier input stage.
That can be explained by the choice of 2n5401 as the input transistors.
Do you know the hFE of the input transistor/s that you used?
regards Andrew T.
Old 22nd April 2012, 05:39 PM   #1164
a.wayne is offline a.wayne  United States
Sin Bin
Martin ,
Andrews rhetoric aside , there was no put down , my response was that of suprise and thanks for clarifying the results ...
Originally Posted by AndrewT View Post
Canon,
I would rather you answer direct questions instead of flying in with your girlish retorts, Instead you take every chance you get for personal insults, even took time to hurl one at Carlos ...
Silly Rabbit ......
Old 22nd April 2012, 05:42 PM   #1165
Sin Bin
Canon,
What about bad music ...?
What would you change it to ..?
Old 22nd April 2012, 06:09 PM   #1166
As per the specsheet, hFE is min 50-60 and max 240. (see pic)
Is there anything bad about these figures and this choice of transistor?
Mart.
Old 22nd April 2012, 06:33 PM   #1167
Sin Bin
What voltage are you operating the amp at Martin ....?
Old 22nd April 2012, 08:13 PM   #1168
64VDC plus 64VDC
Old 23rd April 2012, 08:53 AM   #1169
........... personal insults, even took time to hurl one at Carlos ...
I take exception to Carlos' claims.
I rubbish his behaviour.
I have done it in the past and where/when necessary, I will repeat my confirmation where there are mistakes or bad choices or downright lies.
regards Andrew T.
Old 26th April 2012, 05:00 PM   #1170
Default Output stage bias
Back with more questions...
The output stage bias. Carlos mentioned a way to adjust it: measure the voltage drop across output resistor to obtain 1mV. However in the emitter-follower configuration like the HX, Dr. Self has determined that optimum is very far from that value.
Dr. Self suggest a voltage drop of about 27mV across those 0.47r resistors... Am I missing something, or based on this, Is my amp very underbiased with that 1mV drop??
Please see the pics below that are from Dr. Self's book...
Martin.
Dx Blame ST - Builder's thread - post pictures, reviews and comments here please. destroyer X Solid State 1810 27th July 2016 05:34 PM
group buy for DX Blame MKIII Hx PCBs ByronInPortland Group Buys 252 13th May 2016 04:14 AM
Dx Blame MKIII Supercharged will soon be released destroyer X Solid State 346 22nd April 2014 03:01 PM
Group By: DX Blame MKIII Hx boards ByronInPortland Group Buys 9 19th July 2011 07:21 AM
Dx Blame MKII, an obvious evolution from the Dx Blame ES/ST destroyer X Solid State 4 25th September 2010 06:41 PM
Copyright 1999-2017 diyAudio
