Dx Blame MKIII-Hx  - Builder's thread
Old 25th February 2012, 06:35 PM   #1081
BMW850 is offline BMW850  Netherlands
BMW850's Avatar
Originally Posted by Junie View Post
now i cannot find a 100V in a small package for the capacitor circled in red, can i use a 100uF/50v?
Hi Junie,
I hope this helps, drawing from Carlos.
I use 100volt caps.
Rudy
Itís not what you know, but who you know ďand where they areĒ
Old 25th February 2012, 08:08 PM   #1082
evette is offline evette  Canada
Send a message via Yahoo to evette
Of course you can. Evette
Old 25th February 2012, 09:03 PM   #1083
canonnica is offline canonnica  Canada
Junie, the rating for that capacitor as been established as per if something goes wrong with some of the transistor (I don't recall which one) Carlos has commented it in one of his videos. It's facing very low voltage under normal condition. Mine is 63V
Old 26th February 2012, 02:28 AM   #1084
Junie is offline Junie  Philippines
Cool, thanks.
Old 27th February 2012, 07:27 PM   #1085
I've changed 390R resistance to a 2.2 K resistor.
changing the lower NFB resistor from 390r to 2k2 changes the gain margin and phase margin of the closed loop amplifier.
The amplifier is bound to perform differently, before an after the feedback change.
BMW,
your test and reported conclusion are completely flawed.
Your description of the modification is correct and confirms you are listening to two different amplifiers that by design must perform differently.
regards Andrew T.
Old 27th February 2012, 07:36 PM   #1086
That 100uF capacitor that is the DC block in the NFB path could be a 3Vdc component and the amplifier would still perform well.
If one wants to ensure that the low voltage cap in this blocking position is never abused then add a diode across it so that worst case DC voltage across it is <1Vdc.
You can also add an inverse diode across this same capacitor to protect it from voltage abuse (when something goes wrong) from the other polarity.
Some will report that higher voltage electrolytics perform better than lower voltage electrolytics when passing audio signals.
This DC blocking capacitor should have near zero DC voltage across it, when the amplifier is operating properly and should also have near zero AC voltage across it when the amplifier is operating properly.
A DC blocking capacitor that has no DC voltage and no AC voltage across it cannot contribute to the distortion that the amplifier creates.
i.e. A properly sized DC blocking capacitor cannot be heard.
Make it big and use low voltage if the space/cost requires that.
Use the input capacitors to limit the bandwidth of the amplifier.
regards Andrew T.
Old 28th February 2012, 06:58 AM   #1087
space2000 is offline space2000  Singapore
completed the other part and PSU. how to add two LEDs on Psu _ and + voltage? my psu DC voltage is 60v.
Old 28th February 2012, 08:06 AM   #1088
Rudi_Ratlos is offline Rudi_Ratlos  Germany
Rudi_Ratlos's Avatar
Hi Space2000,
the voltage drop across a standard LED is about 2V.
To let the LED shine with say 5mA, you must calculate the value of a resistor across which 58V (since you are using a +/- 60 VDC PSU) will drop while 5mA is flowing.
Take a 10K resistor, connect the cathode of the LED to GND, the anode of the LED (the anode's leg is the longer one) to one side of the resistor and the other side of the resistor to your positive rail voltage.
Reverse the LED while connecting to the negative power rail.
Best regards - Rudi_Ratlos
Old 28th February 2012, 12:04 PM   #1089
Originally Posted by Rudi_Ratlos View Post
Hi Space2000,
Thanks for help.
Old 28th February 2012, 02:31 PM   #1090
Andrew, isn't it adding a diode in NFB will rectify the output signal which lead to DC presence in the input stage? Maybe i'm wrong
Dx Blame MKIII-Hx  - Builder's threadHide this!Advertise here!
Dx Blame ST - Builder's thread - post pictures, reviews and comments here please. destroyer X Solid State 1874 28th August 2017 10:53 PM
group buy for DX Blame MKIII Hx PCBs ByronInPortland Group Buys 252 13th May 2016 05:14 AM
Dx Blame MKIII Supercharged will soon be released destroyer X Solid State 346 22nd April 2014 04:01 PM
Group By: DX Blame MKIII Hx boards ByronInPortland Group Buys 9 19th July 2011 08:21 AM
Dx Blame MKII, an obvious evolution from the Dx Blame ES/ST destroyer X Solid State 4 25th September 2010 07:41 PM
