Dx Blame MKIII-Hx  - Builder's thread
Closed Thread
Old 20th February 2012, 05:00 PM   #1011
BMW850 is offline BMW850  Netherlands
BMW850's Avatar
Nothing about voltage drop ...
I thought the proper operation you need to have a stable power supply
currentflow,
Thanks for the explanation, I definitely try 470uF C1 and C2
Rudy
Itís not what you know, but who you know ďand where they areĒ
Old 20th February 2012, 07:21 PM   #1012
currentflow is online now currentflow  United Kingdom
currentflow,
Rudy
Hi Rudy,
Since you'll be using these modules to protect your speakers, it's worth spending a little time to ensure they operate reliably.
Your measured voltage of 15.1V before the regulator when the relays are on is now greater than the minimum required value of 14.5V, which is good news. As we don't know how much ripple is present before the regulator, the changes to C1 and C2 would definitely be beneficial although their values are not critical. You could use 330uF or 470uF with a minimum working voltage of 25V to improve on the results. Select the largest of these values which will comfortably fit on the PCB. Another possibility would be to fit a single 1000uf/25V instead of two capacitors, if there is room.
currentflow
Old 21st February 2012, 02:46 PM   #1013
BMW850's Avatar
Hello currentflow,
Thanks for your help, I now have a 1000uF capacitor soldered in there, and the speaker protection module is now stable.
Thanks vintage audio lab for a "good and stable speaker protection module you send me"
We on this forum do the research to make this a good and stable working speaker protection module
Rudy
Old 21st February 2012, 03:47 PM   #1014
Hello currentflow,
Rudy
One of the pleasures of DIY is in improving others' designs... Out of curiosity, what is the voltage before the regulator now that you've changed the capacitors, with the relays on? Over 16V?
Steve
currentflow
Old 21st February 2012, 07:08 PM   #1015
BMW850's Avatar
Steve
Hi Steve,
Everything is now connected and the speaker protection module works.
Input voltage 7812 regulator with the relay on, is now 16, 67v
Rudy
Old 21st February 2012, 07:20 PM   #1016
Hi Steve,
Rudy
Looks good to me. Now enjoy your Hx!
Steve
currentflow
Old 22nd February 2012, 04:29 PM   #1017
canonnica is offline canonnica  Canada
Default Question on gain
Hi everyone, quick question here...
The gain of the Hx amp seems very high compared to "consumer" power amps. Basically, a consumer amp rated at 200W RMS into 8 Ohms will show a gain averaging at around 28x.
Now when I look back at the schematics of the Hx, the gain seems to be around 120x. Am I missing something?
I think Carlos determined that 390Ohm resistor for direct connection to portable devices, hence the huge gain ratio.
Picture showing the two resistors used for calculating the gain:
Old 22nd February 2012, 04:34 PM   #1018
a.wayne is offline a.wayne  United States
Sin Bin
Can you or has anyone measured the signal to noise ratio .... ?
Old 22nd February 2012, 04:43 PM   #1019
astankov is online now astankov  Bulgaria
astankov's Avatar
I had similar question in the past and Carlos answered me that I can change the value of the 390R resistor to adjust the gain of the amp.
Also I think that gain is determent by the two resistors in the NFB and not by this in the input to the GND. In this case you are right because they have the same value but keep it in mind.
Regards!
Old 22nd February 2012, 05:09 PM   #1020
evette is offline evette  Canada
Send a message via Yahoo to evette
You are correct Gain =r2+r3\r2===121.5 Evette
Closed Thread
Dx Blame MKIII-Hx  - Builder's threadHide this!Advertise here!
Dx Blame ST - Builder's thread - post pictures, reviews and comments here please. destroyer X Solid State 1874 28th August 2017 09:53 PM
group buy for DX Blame MKIII Hx PCBs ByronInPortland Group Buys 252 13th May 2016 04:14 AM
Dx Blame MKIII Supercharged will soon be released destroyer X Solid State 346 22nd April 2014 03:01 PM
Group By: DX Blame MKIII Hx boards ByronInPortland Group Buys 9 19th July 2011 07:21 AM
Dx Blame MKII, an obvious evolution from the Dx Blame ES/ST destroyer X Solid State 4 25th September 2010 06:41 PM
